d16 to d16 swap q:
Old Mar 17, 2005 | 04:32 AM
tommytoes's Avatar
Default d16 to d16 swap q:
I tried searching for all kinds of things and came up with nothing (useful).
Q: I want to upgrade the d16 in my 88 crx si and wanted to know if the newer d16's have the same mounts. I plan on keeping it obd0 so I will keep the distributor, alternator, injectors and sensors.
Is this feasible?
and if possible some links to topics where this has been done.
Thanks
Old Mar 18, 2005 | 03:12 AM
tommytoes's Avatar
Default Re: d16 to d16 swap q: (tommytoes)
come on people the question seems simple enough gimme a link or something
Old Mar 18, 2005 | 03:15 AM
PaImportTuner's Avatar
wow hell man i havent done a D t o 92+ D in forever.
you have to change the driver side mount on the newer D, using your current driver side d16a6 mount. yeh you can keep it obd0 too and bolt the rest up.
Old Mar 18, 2005 | 03:47 AM
tommytoes's Avatar
Default Re: d16 to d16 swap q: (PaImportTuner)
Does this still apply for the d16's that come out of the EK's? Or are they all the same?
Old Mar 18, 2005 | 04:24 AM
yeh man. all 92-00'(d15b7,d16z6, d16y7,d17y8 and so on) D series front and passenger side mounts bolt into EF. tranny and driver side you use for the year of car 88-91 ef in your case..
Old Mar 18, 2005 | 05:49 AM
crazyboutsti's Avatar
can u guys help me out with my swap i need electrical
Old Mar 18, 2005 | 05:55 AM
Default Re: d16 to d16 swap q: (crazyboutsti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyboutsti &raquo;</TD></TR><TR><TD CLASS="quote">can u guys help me out with my swap i need electrical</TD></TR></TABLE>
need info:
which motor you swapping in, ecu your using and car model crx/civic? dx,lx,hf,si?
Old Mar 18, 2005 | 08:46 AM
tommytoes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">yeh man. all 92-00'(d15b7,d16z6, d16y7,d17y8 and so on) D series front and passenger side mounts bolt into EF. tranny and driver side you use for the year of car 88-91 ef in your case..</TD></TR></TABLE>
Thanks alot man
91efbluehatch
17
Jun 25, 2011 06:23 PM
88 EF Hatch
Mar 3, 2009 06:21 PM
jdm_92_gsr
May 10, 2003 04:46 AM
G2turbo_terror
Nov 30, 2002 05:45 PM
CTR94Joes
10
Oct 30, 2002 12:39 PM
