engine help
i'm planning on purchasing a gsr engine, i went to http://www.hmotorsonline.com and was reading what came with the engine what else would i need besides the following:
- Motor
- Hydraulic Tranny (S80, Y80)
- ECU (P72)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
- Motor
- ECU (P72)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
if you get the complete swap from steve,
throttle cable,
ac bracket if you want to keep air off of a del sol vtec
fluids
filter
and nuts and bolts.
throttle cable,
fluids
filter
and nuts and bolts.
mounts, axles, all your fluids (oil filter), spare wire and wire terminals, and $200 you can burn on emergency stuff just in case. You probably won't need that much, but you don't want to run out of funds in the middle of a swap.
True, probably best to back yourself up with some cheese just in case. I would say mounts and those axles. Oh wait someone said that. Well its confirmed then
b18civicdx
Aug 10, 2004 08:46 PM
mugensport9
32
Sep 7, 2003 10:04 PM
