BIG PROBLEM: End of compression tester is stuck in the head!
Old Mar 16, 2005 | 06:41 PM
Brand's Avatar
Default BIG PROBLEM: End of compression tester is stuck in the head!
OK, the adapter of my compression tester is stuck in my cylinder head. So I put super glue on the piece with the hose and screwed it on and let it dry. I figured that when i turned that, it would all come out. But now both pieces are stuck together. What do I DO !? I am so pissed right now. I have some wd40 soaking on it right now because its too late to go out and buy that PB Blaster stuff. Guys help me out.
Old Mar 16, 2005 | 07:17 PM
Dragline's Avatar
Default Re: BIG PROBLEM: End of compression tester is stuck in the head! (Brand)
Try some 12" needle nose pliers.
Old Mar 16, 2005 | 07:20 PM
Brand's Avatar
and what am i gonna do with those? Theres a hose coming out of the hole
Old Mar 16, 2005 | 07:24 PM
Dragline's Avatar
Default Re: (Brand)
They make ones that are made for removing hoses you can get them in a variety of size's
Old Mar 16, 2005 | 07:26 PM
Dragline's Avatar
Default Re: (dragline)
Something similar to these
http://www.thetoolwarehouse.net/shop/SUN-3705.html
Old Mar 16, 2005 | 08:21 PM
TwinOptiX's Avatar
Use the 12" pliers to get a hold of the metal part of the hose adapter that's in the spark plug hole. The WD-40 is going to help you get it loose. Your going to need to use some elbow grease, but you'll get it loose.
No one said working on cars is easy.
Old Mar 16, 2005 | 08:57 PM
Fuster_Cluck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brand &raquo;</TD></TR><TR><TD CLASS="quote">OK, the adapter of my compression tester is stuck in my cylinder head. So I put super glue on the piece with the hose and screwed it on and let it dry. I figured that when i turned that, it would all come out. But now both pieces are stuck together. What do I DO !? I am so pissed right now. I have some wd40 soaking on it right now because its too late to go out and buy that PB Blaster stuff. Guys help me out.</TD></TR></TABLE>
Same thing happened to a group of us HT'ers when doing compression tests. I was going to say use super glue, but I see you've done that. So, you just can't turn the hose to break the tester loose? I'm not sure if I understand what you did.
Subscribing anyhow / good luck
Old Mar 17, 2005 | 05:58 AM
Brand's Avatar
I am turning the hose, but the hose isnt turning the piece down in the motor. I dont see how needle noce pliers would do the trick
Old Mar 17, 2005 | 10:07 AM
littleRedCorvette's Avatar
Default Re: (Brand)
The problem that you are getting right now w/ the hose not twisting off the metal part is that there is too much torque lost from the hose compared to how tight the metal piece/adapter is on.
Basically, the other guys suggested needle nose pliers because you can use it to effectively clamp the part down and twist it off. It won't be that easy, but given the situation, there seems to be little else. Unless you can get a wrench/breaker bar combo going on to clamp that piece down, the needle nose pliers are probably your best bet.
You may have to cut most of the hose off now, since it's not working anyway, to give yourself some room to work with. Showing everyone a picture of what it currently looks like from different angles will give everyone a better idea of how to get that sucker loose.
Next time use some anti-seize.
Old Mar 17, 2005 | 07:35 PM
Brand's Avatar
my mechanic did it for me... all he charged me was some of my mom's cookies
Old Mar 18, 2005 | 04:18 AM
JimBlake's Avatar
Default Re: (Brand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brand &raquo;</TD></TR><TR><TD CLASS="quote">my mechanic did it for me... all he charged me was some of my mom's cookies</TD></TR></TABLE>... and probably the rights to tell the story & laugh about it.
Old Mar 18, 2005 | 05:18 AM
b204dr's Avatar
did you see what he did to remove it - and where they chocalate chip!
alex14
10
Dec 3, 2010 02:16 AM
hometheaterman
Apr 3, 2010 10:44 AM
vegas hoe
Feb 16, 2008 05:06 AM
cornhusker
May 21, 2004 08:24 PM
typer_801
Feb 5, 2003 01:12 PM
