Grounding in the cab instead of the engine compartment?
Old Mar 16, 2005 | 05:49 PM
Littlemarcins's Avatar
Default Grounding in the cab instead of the engine compartment?
Is it possible and safe to ground electrical equipment to metal inside the cab instead of the engine compartment? Will there be any negative or different results?
Old Mar 16, 2005 | 06:11 PM
philadd's Avatar
Default Re: Grounding in the cab instead of the engine compartment? (Littlemarcins)
Sure... When stereo shops install amps, they ground them back there as well. Just make sure you ground whatever it is to bare metal (scratch off any paint if necessary).
Old Mar 16, 2005 | 06:24 PM
Default Re: Grounding in the cab instead of the engine compartment? (philadd)
Oh thanks man! You just saved me a lot of time because I was going to attempt the harder route. Thanks again.
TravisB16a
May 16, 2008 05:27 PM
TURBODC4TEG
Oct 15, 2007 12:11 PM
kyle45
11
Aug 30, 2007 06:43 PM
GetawayInMoscow
Jun 23, 2003 09:43 AM
