fuel pressure ???
Old Mar 16, 2005 | 03:47 PM
cherroneballs's Avatar
Default fuel pressure ???
hi
I was just wondering what fuel pressure to run on ls with bolt ons??? I have it at 40psi right now. it will pull hard but acts like a vtec motor when it hits 4000 rpms it just pulls real hard. didn't know if thats the nature of the ls or if I have my fuel pressure to high or to low???
Old Mar 16, 2005 | 04:22 PM
suspendedHatch's Avatar
Default Re: fuel pressure ??? (cherroneballs)
stock fuel pressure
unless you mean FI bolt ons.
Old Mar 16, 2005 | 04:24 PM
_gurusan_'s Avatar
Default Re: fuel pressure ??? (shaundrake)
I have a related question about fuel pressure.
When you adjust it do you disconnect the vacuum source? Or do I leave the connection to the intake manifold on and adjust it?
Old Mar 17, 2005 | 07:11 AM
I am pretty sure that youleave the hose on.
Old Mar 17, 2005 | 07:51 AM
Reiketsukan's Avatar
Default Re: (cherroneballs)
I don't mean to jack this thread, but when you do a swap, (like an LS into a Sol), do you need to replace the stock fuel pump with one from the car you got the motor out of? Will a stock civic fuel pump work reliably with a swaped motor?
Thanks in advance!
Old Mar 18, 2005 | 08:31 AM
yes the fuel pump in the civic will be fine.
Old Mar 18, 2005 | 08:45 AM
ssbpturbohatch's Avatar
just swap the fuel pump with something like a walboro 255, 310cc injectors, and MSDign. system or equal and dont worry about the pressure, thats what my friend did to up his HP, or just leave it at stock if you dont wanna drop the cash on the other stuff
Old Mar 18, 2005 | 08:56 AM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure that youleave the hose on.</TD></TR></TABLE>
Hose comes off for adjusting. It doesn't really matter, but the pressures given are usually with the hose off.
Old Mar 19, 2005 | 09:03 AM
if I take my hose off my fuel pressure sky rockets
Old Mar 19, 2005 | 09:40 AM
GeeReg's Avatar
It's supposed to. (Well maybe not skyrocket but go up 5-10psi)
092eg6
Dec 11, 2009 01:36 PM
Vtec-Mike
Jan 7, 2006 10:02 AM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
HybridCoupe
Jul 6, 2002 03:48 PM
