MPFI question
Old Mar 16, 2005 | 03:24 PM
silver hatch's Avatar
Default MPFI question
i am swapping a zc intp my 1991 civic. i am wiring mpfi, and i wanted to clear something up.
from my understandin the dx has two injector plugs on it. i cut these off and then solder the yellow/black wires together and run it to the yellow/black wire on the injector resistor box.
is this correct?
Old Mar 16, 2005 | 03:37 PM
doublethink's Avatar
Default Re: MPFI question (silver hatch)
https://honda-tech.com/zerothread?id=979961
"MPFI" in CRX/EF Forum with Archive checked:
» Search Results
Your search for MPFI returned 591 results.
Old Mar 16, 2005 | 04:16 PM
Default Re: MPFI question (doublethink)
i wasnt looking for a smart *** reply, i was asking if i understood the directions correctly.
Old Mar 16, 2005 | 04:20 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver hatch &raquo;</TD></TR><TR><TD CLASS="quote">i wasnt looking for a smart *** reply, i was asking if i understood the directions correctly.</TD></TR></TABLE>
This site has a good write-up also...
http://effinmotorworks.com/Effin_MPFI_swap.htm
Old Mar 16, 2005 | 04:43 PM
See65's Avatar
You are correct.Heres a site with a good write up also its the one I used.http://www.geocities.com/teampimports/fuelinj.html
Old Mar 16, 2005 | 05:47 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver hatch &raquo;</TD></TR><TR><TD CLASS="quote"> i cut these off and then solder the yellow/black wires together and run it to the yellow/black wire on the injector resistor box.
is this correct?</TD></TR></TABLE>
Yup. and if you need an expert to handle it, check out rywire.com
Ryan
Tippyman
Mar 23, 2006 01:38 PM
Tippyman
Mar 23, 2006 06:40 AM
Dunc
Oct 2, 2005 02:12 PM
Kilohead36
May 4, 2003 05:07 PM
