paper filter or foam filter?
Old Mar 16, 2005 | 10:49 AM
blue_hatch's Avatar
Default paper filter or foam filter?
as the topic asks. which would you recomend for eg cold air intake.
Old Mar 16, 2005 | 10:51 AM
eK9aT10pSi's Avatar
Default Re: paper filter or foam filter? (blue_hatch)
k&n filter
Old Mar 16, 2005 | 10:52 AM
marshun's Avatar
foam. i remember watching this video where they were testing the different types of filters from different companies. the foam one's did better.
Old Mar 16, 2005 | 10:58 AM
blue_hatch's Avatar
its for a cold air set-up. will the foam still be good if its wet?
Old Mar 16, 2005 | 11:06 AM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch &raquo;</TD></TR><TR><TD CLASS="quote">its for a cold air set-up. will the foam still be good if its wet?</TD></TR></TABLE>
good question. but then that kinda goes the same way for the paper filter too huh?
Old Mar 16, 2005 | 11:27 AM
Targa250R's Avatar
be professional
Foam filters usually (not always) flow the best, but don't filter as well as a paper filter usually does.
K&N-type cotton gauze & wire mesh filters are usually the best compromise. Like a foam filter, they can be cleaned and re-used.
Just keep your fender liner and you won't have to worry about it getting soaked . . .
Here are a couple of filter tests:
http://www.mkiv.com/techarticles/filters_test/2/
http://www.ftooc.org/contents/...r.htm
Old Mar 16, 2005 | 11:40 AM
Targa250R's Avatar
be professional
Default Re: paper filter or foam filter? (Targa250R)
BTW, take those filter tests with a grain of salt and ignore the horsepower for the most part. In the first test, the Apexi filter did flow better than the K&N, but keep in mind that the Apexi is expensive and not clean-able, so you'd have to fork out some cash to replace it every so often (don't buy Apexi's claim that it is a "lifetime" filter). It is also a dry-type filter, which is more of a concern around water than an oiled filter is.
Old Mar 17, 2005 | 06:00 PM
blue_hatch's Avatar
thanks for the info
does k&n come with a 2.5 inch inlet? isint it always 3 inch.
Old Mar 17, 2005 | 11:08 PM
marshun's Avatar
k&n actually makes allot of difference sizes. i've seen a k&n filter for a moped.
skylinevo
Jul 7, 2006 08:47 AM
accord0494
Apr 9, 2005 06:38 PM
djsgtrip
Feb 19, 2005 03:57 PM
-faded-
Aug 29, 2004 08:08 AM
Brian-Brian
Jun 5, 2003 09:35 AM
