race gas on a stock si?
Old Mar 16, 2005 | 10:40 AM
I Quarantined I's Avatar
Default race gas on a stock si?
is it safe to turn 100 octane on my stock si at the track?
Old Mar 16, 2005 | 11:25 AM
.dave's Avatar
i HAS questions ?
Default Re: race gas on a stock si? (I Quarantined I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Quarantined I &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to turn 100 octane on my stock si at the track?</TD></TR></TABLE>
Safe? Yes. Is there any reason to? No.
Old Mar 16, 2005 | 11:26 AM
siblueg's Avatar
if its unleaded it wouldn't hurt it, it would also clean up your injectors a little. if it's a stock si you really wouldn't be able to tell that big of difference. But it sure smells good when you burn it though.
Old Mar 16, 2005 | 04:51 PM
97mini-me's Avatar
Default Re: race gas on a stock si? (1 cam)
How about for a jdm itr engine? Stock?
I run 94 octane now.
Old Mar 16, 2005 | 09:07 PM
Jokerluv's Avatar
it will help a little but not a whole hell of alot
Old Mar 16, 2005 | 09:15 PM
ndogg's Avatar
Default Re: (Jokerluv)
it would probably hurt performance. 100 octane will be a slow burn... unless you retune your fuel and advance your ignition maps, i don't think it will help at all.
Old Mar 17, 2005 | 10:04 AM
Rtype16's Avatar
Default Re: (ndogg)
Ndogg is completely right. Unless your vehicle needs 100 octane it will most likely hurt you more than help you. 100 octane does burn slower and unless your motor really needs it you are better off with 94 on a Type-R motor. For like a D16 I would run 87. You will see more power with 87 than with 91.
Old Mar 17, 2005 | 10:33 AM
PM-Performance's Avatar
Default Re: (Rtype16)
it wont make any difference.
For the person who made the post, do you have any idea why people use race gas? or are you one of those people that buys plug wires and considers them an updgrade?
Unless you have some real mods, that can benefit from the timing advance that the race gas will allow you its not worth the effort.
Old Mar 17, 2005 | 10:41 AM
CNSK's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">it wont make any difference.
Unless you have some real mods, that can benefit from the timing advance that the race gas will allow you its not worth the effort. </TD></TR></TABLE>
my thoughts exactly...
Old Mar 17, 2005 | 07:24 PM
yo *** it was a question...i just wanted to know if it would hurt my car or not cuz someone i know with the same car told me i should run it i should go faster but i didnt know if it was safe or not...but thanks for your comments and 2 cents
Old Mar 18, 2005 | 07:59 AM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Ndogg is completely right. Unless your vehicle needs 100 octane it will most likely hurt you more than help you. 100 octane does burn slower and unless your motor really needs it you are better off with 94 on a Type-R motor. For like a D16 I would run 87. You will see more power with 87 than with 91.</TD></TR></TABLE>
never knew that, how does that work? i used 100 in my slightly modded H22 and felt a slight difference
Old Mar 18, 2005 | 01:26 PM
ndogg's Avatar
Default Re: (Matt5745767)
probably the placebo effect.
Old Mar 18, 2005 | 05:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (ndogg)
How does it hurt you??
Old Mar 18, 2005 | 09:10 PM
ndogg's Avatar
Default Re: (cb7-R)
peak cylinder pressure will come too late in the stroke for max power. unless you tune for race gas (increase timing).
Old Mar 19, 2005 | 01:52 AM
JonnySBeee...'s Avatar
plus 100 octane is doo mdan expensive!!
Old Mar 19, 2005 | 10:41 AM
DSMJim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">never knew that, how does that work? i used 100 in my slightly modded H22 and felt a slight difference</TD></TR></TABLE>
Thats because your wallet was lighter giving you a better power / weight ratio. Higher octane will hurt you on a stock car. Stick to whats recommended. Your not going to gain power by running a high octane on a stock car. Guys who fill up stock cars with 94 are idiots and wasting their money.
Higher octane burns slower and as a result a stock car will make less HP because it's taking longer to get a complete burn. When that complete burn happens your too far after TDC and the power isn't being applied to the piston at the right time.
Old Mar 19, 2005 | 10:41 PM
1point5CRX's Avatar
Default Re: (DSMJim)
been curious about this..... some people run higher octane than need but what happens if they try to run a hotter plug with it also, or run 87 oct with a hot plug but raise theyre FPR? whats the effects with these diff combos?
Old Mar 20, 2005 | 12:40 PM
DLB1994's Avatar
Default Re: (1point5CRX)
get some VP U4 gas or some VP MRX01 gas i bet u will pickup a few hp lol
Old Mar 24, 2005 | 01:54 AM
JdmEg6Hybrid's Avatar
Default Re: (DLB1994)
How about 115 octane race gas on a gsr with 75 shot of nos
e DoGG 4 sHo
Honda Civic (2006 - 2015)
11
Jun 17, 2008 10:29 PM
06BlackSi #45
21
Oct 27, 2006 11:40 AM
mkinpwrat12g's
13
Aug 31, 2005 11:31 AM
jerbear!
17
Apr 7, 2004 08:16 PM
udm_motorsport
Apr 5, 2004 05:50 PM
