anybody need CAD drawings???
Im working on a set of cam gears. Nothing is to spec, but Im just trying to figure out how exactly they work, what I need, complications, etc.
Rich
If you wanna make a IHI VF-series turbo flange, thatd be great!
Rich
i would kinda need some dimensions and a general idea of what it would look like im not really a turbo guy so turbo lingo just confuses me
but thanks for an idea
yeah there are a bunch of b18 flanges around but ill see what i can do. also i am using autocad 2004
im thinking about designing an equal legth race header with a dump tube at the bottom any suggestions on that
Equal length is not the only thing you also must consider the optimum length.
Try solid works or maybe rhino i believe its alot easier to draw 3D in those progs
what program(s) are you guys using?? im using autodesk architectural desktop and autodesk inventor 8---im tryin to get into autodesk viz, but prolly wont happen
CAM GEARS ARE PRETTY EASY.. JUST FIND THE DIAMETER THEN COUNT HOW MANY PIONTS YOU NEED THEN USE THE ARRAY FUNCTION TO CREAT THE OUTER SECTION, AND THE INSIDE IS PRETTY BASIC.
IF YOU WANT A PIC I HAVE SOME OF A RATCHET GEAR IF YOU WANT SOMETHING TO REFERANCE.
GOOD LUCK
GOOD LUCK
ahhh, the 'ar' command, how i love thee. My biggest problem is that I have taken a cam gear off yet to see how they fit. Im completely slacking and my final project is due in 7 weeks. The biggest *** so far is the tooth design, measuring it, and making it look correctly.
Send me those dwg's if u have them
Rich
PS> is there i way i can make a jpeg of my ACAD (2002 baby woo!) dwgs so I can share them?
Rich
Hey, i do
this might be intresting to make.
93 hatchback si with a s2000 motor i need to see the possible ways i might do it
with putting in the driveshaft and diff.
if you can do that it would be cool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Border9 »</TD></TR><TR><TD CLASS="quote">Hey, i do
if you can do that it would be cool</TD></TR></TABLE>
Time to make a tranny/driveshaft tunnel
Rich
Rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pills_PMD »</TD></TR><TR><TD CLASS="quote">i've been using Unigraphics NX2, solid works and autocad 2005 LT... i prefer UG-nx2 over all the rest...
i have a copy of pro E , but as stated.. pain in the ***!</TD></TR></TABLE>
Same here, i am in NX2. I am also taking classes for ProE, its different, has its good and bad sides.
Hey i am looking for a new job, any openings over there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pills_PMD »</TD></TR><TR><TD CLASS="quote">lol thats a photoshop request rather than a CAD request...
MY_EL_1 : i am a student intern at a company, so am i not sure if they are hiring.</TD></TR></TABLE>
Photoshop forsure, that would take a lot of surfacing design, hell weeks.
Ok thanks, what do they make?
Yeah guy i need 3d drawings of the 85 Honda gyro 85 for some CAD work. The problem is i can find any on line and i cant find a way of buying any form Honda itself is possible you can draw up some or find some e-mail me at honda_gyro_50@yahoo.com if you would please.
Thank you,
Juan
Thank you,
Juan
I need a drawing of a IM flange for a jdm b18c5. I'd draw my own but I don't have one to measure. If no one has one I'll just order a gasket to measure, but it'd be nice if someone else had one for me to use.
id like to see how it will look
