problem with Ignition coil
On a jmd crx with b16a I would like to know if there is a constant 12 volt power supply to the ignition coil (black/yellow wire) when the key if in the off position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSED_CRX_VTEC »</TD></TR><TR><TD CLASS="quote">On a jmd crx with b16a I would like to know if there is a constant 12 volt power supply to the ignition coil (black/yellow wire) when the key if in the off position.
With the key off, no.
jefe
May 26, 2006 08:21 PM
