size of 954RR ITBs??
Old Mar 16, 2005 | 07:13 AM
thehatchninja's Avatar
Default size of 954RR ITBs??
i dont know if this is the best place to ask this q.....but help me out if you can.
i know the 929 is 38mm, and i have a suspicion that the 954rr is 42mm, but i don't know why.
does anyone know?
Old Mar 16, 2005 | 07:36 AM
CRVTEC0WNZJ00's Avatar
Default Re: size of 954RR ITBs?? (thehatchninja)
I believe they're 42mm at the throttle plate. too small for my setup I think and I'd rather buy a real set than some crap someone made or that I made.
Old Mar 16, 2005 | 08:41 AM
Default Re: size of 954RR ITBs?? (CRVTEC0WNZJ00)
way bigger than a single 65mm
Old Mar 24, 2005 | 02:56 PM
Circuit Star-29's Avatar
48mm down to 42mm
Old Mar 24, 2005 | 06:47 PM
Default Re: size of 954RR ITBs?? (C-speed Racing)
thanks c-speed, i used your swap instructions to do my swap a year ago.
Old Mar 25, 2005 | 12:35 AM
Glad we could help out. Let me know if you need any help with your itb set up as I've done a few.
Old Mar 25, 2005 | 06:34 AM
Kendall's Avatar
If it's going on a relatively stock motor, you may want to note that the 954RR fuel injectors have the same flow rate as the stock B series fuel injectors.
Old Mar 25, 2005 | 10:00 AM
thanks
Old Mar 27, 2005 | 02:23 AM
Hater's Avatar
Default Re: (thehatchninja)
I've had a set of what I believe to be 929 throttle bodies sitting around for over a year, that I planned on trying to mod to my B16 but never got around to do. How different are the 929 and the 954 setups?
Old Mar 27, 2005 | 08:59 AM
kndaqikEG's Avatar
I am pretty sure that is correct, and the GSXR750/1000's are 43mm and twm and other "real" itb's are 44mm.
Old Mar 27, 2005 | 09:48 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hater &raquo;</TD></TR><TR><TD CLASS="quote">I've had a set of what I believe to be 929 throttle bodies sitting around for over a year, that I planned on trying to mod to my B16 but never got around to do. How different are the 929 and the 954 setups?</TD></TR></TABLE>
The 954 setup is 4mm larger at the throttle plate than the 929 setup. Consider a Suzuki setup as you can build an equal length setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kndaqikEG &raquo;</TD></TR><TR><TD CLASS="quote">the GSXR750/1000's are 43mm</TD></TR></TABLE>
The most usable GSXR 750/1000 setups are 42mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kndaqikEG &raquo;</TD></TR><TR><TD CLASS="quote">twm and other "real" itb's are 44mm. </TD></TR></TABLE>
Is this to say that the Suzuki setups are inferior in some way? Hayabusa throttle bodies are 46mm at the plate.
-Kendall, who's upcoming 48mm Hayabusa setup should come within swinging distance of the Jenvey's on a flow bench. Muah-ha-ha-ha-ha.
Old Mar 28, 2005 | 04:44 AM
kndaqikEG's Avatar
Default Re: (Kendall)
No implication of inferiority at all, just trying to state what I "thought" I knew.
johnmota
23
Jul 23, 2015 10:55 PM
alexb16hb
May 13, 2006 10:18 AM
rikawa
Nov 7, 2005 06:01 PM
Arturbo
Jan 9, 2002 06:20 AM
