diameter of 94-01 tegs head lights?
Old Jan 23, 2002 | 08:38 PM
zijiejijeijrkjk's Avatar
Default diameter of 94-01 tegs head lights?
posting for a friend. i dont have a teg in front of me to check. anyone know?
thanks.
Old Jan 23, 2002 | 08:40 PM
Rboosted717's Avatar
Default Re: diameter of 94-01 tegs head lights? (elements)
the 98+ teg headlights are different then the 97-below headlights. The 98+ headlights are larger and are at more of an angle vs. the flat/non-angled 97- below headlights. As for the exact size, I have no idea.
Old Jan 23, 2002 | 08:59 PM
Default Re: diameter of 94-01 tegs head lights? (Rboosted717)
anyone else?
Old Jan 23, 2002 | 09:02 PM
B2FiNiTY's Avatar
Just wondering, why do you need this?
Old Jan 23, 2002 | 09:05 PM
Default Re: diameter of 94-01 tegs head lights? (B2FiNiTY)
something to do with mr2 headlight replacements. and i dont have the specifics.
[Modified by elements, 7:00 AM 1/24/2002]
Old Jan 23, 2002 | 09:16 PM
ITRinEJ1's Avatar
this isnt my account...but i am the one looking actually... the body work on my 92 mr2 is in progress right now. I am modifying the swing arm and "pushrod" arm on the headlights motor so that headlights do not raise so far. The fiberglass guy will be making a new light housing to "shroud" the lights or whatever you want to call it. However I have been having trouble locating some nice round shaped lights that would be safe and adequate for use for real headlights. I figured if the 94-97 teg lights were both the same diameter on the high and low beam, had flat (or extremely close to it) lenses, and were of a small enough diameter... then my best bet would be to pick up a set and fabricate the mounts and wire them up. Also, if anyone wtih a JDM ITR front end wants to sell their stock teg lights and they are good size... then I am in the market for them.
-Charles
Old Jan 23, 2002 | 09:20 PM
d8168055's Avatar
Default Re: diameter of 94-01 tegs head lights? (ITRinEJ1)
uuuuuuhhhhh..... noooo....
Old Jan 24, 2002 | 08:02 AM
Default Re: diameter of 94-01 tegs head lights? (d8168055)
ttt
Old Jan 24, 2002 | 08:08 AM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
My friend is doing the same thing on his s13. He got those headlight controllers (so it only flips up a certain amount) and I told him that he should just buy some catz drving/fog lights and custom that into his stock headlights. Its way cheaper than spending $800-$1,000 on custom made projectors.
jus my 2 cents,
jOEL
ajjct
21
Apr 27, 2013 09:41 AM
94HONDAHEAD
May 7, 2007 06:45 PM
rasinhell
Feb 17, 2005 04:35 AM
hkshiper
May 6, 2004 06:15 AM
