Good deal ITR cams?
Old Jan 23, 2002 | 08:11 PM
LOwrestling2001's Avatar
Default Good deal ITR cams?
I've been looking for cams around 300-400 bucks... iwas thinking about getting one CTR cam...but i've heard there's been a lot of scamming going on w that ....so i think imma get ITR cams for my 98 gsr...this will be a good performance mod no? anyhow...this guy will sell me his used ones 99 itr cams used for 1k miles...for 350 (and he has a shop and will install it)...so 350 installed...how does that sound? is that good?
Old Jan 23, 2002 | 08:22 PM
fiebru1119's Avatar
Default Re: Good deal ITR cams? (LOwrestling2001)
both cams for 350 is a good deal wether or not its installed, the cheapest i've found is 500/pair or 300/ea so if its a good deal... as for the CTR scams on the cams, i'd like to know more about that myself because that was gonna be my next mod (CTR intake and ITR exhaust), yes they are a good mod, but w/out the respective (CTR/ITR) valvesprings/retainers, be careful tryin to rev much past 8000
Old Jan 23, 2002 | 09:10 PM
StinkyTofu's Avatar
Default Re: Good deal ITR cams? (fiebru1119)
there little difference between the CTR intake and ITR intake cam. 3 degrees more duration. I don't know why, but for a b18 motor, it is less beneficial as opposed to a b16 motor. you will feel no difference.
Old Jan 24, 2002 | 01:39 AM
onefastcx's Avatar
well that is a good deal the lowest ive seen is 550 a pair i would get the ctr intake cause it has a higher duration that the itr and the just get the itr exhaust cam cause the ctr and itr exhaust are the same
Old Jan 24, 2002 | 11:41 AM
nwarp's Avatar
Default Re: Good deal ITR cams? (onefastcx)
If you do get ITR cams I would only suggest getting 00-01' year cams because other ITR cams before these years have a lower lift duration & bigger VTEC lobes, and the 00-01' ITR cams are soooooooooooooooooooooooo similar in spec compared to the CTR cams.
[Modified by SPOON SPEC DC2, 8:42 PM 1/24/2002]
rico suave
May 27, 2012 09:32 PM
GsR92HaTcH
14
Mar 14, 2006 12:30 AM
dornon13
Jul 17, 2004 11:48 AM
JDMlyfestyle
Nov 1, 2003 06:26 PM
498GSR
Oct 28, 2002 10:06 PM
