Oil problem.......
Old Mar 15, 2005 | 09:42 PM
MrPotatoeHead's Avatar
Default Oil problem.......
Ok today I went and checked my oil,and I was REALLY low.....The thing is ive NEVER noticed any smell of oil burning, no blue smoke and no oil in muffler. Where is it all going? And I keep having to fill up my radiator with antifreeze...Could that have something to do with it????Ive shearced and come up with a whole lot of unusable info.......Please help...
Old Mar 15, 2005 | 09:47 PM
Immanuel's Avatar
Default Re: Oil problem....... (OnE sToCk CrX)
bump, because Iam in a similar situation
Old Mar 15, 2005 | 09:49 PM
crxnj's Avatar
headgasket maybe leaking oil and coolant..
No white smoke??
Old Mar 15, 2005 | 09:51 PM
Immanuel's Avatar
Default Re: Oil problem....... (Mr.speaker)
I dont see any white smoke, the odd thing is that, my car runs way smooth when the heater is on and its set to 1, but if I turn of the heater the car runs like ****, what could cause this?
Old Mar 15, 2005 | 09:55 PM
crxnj's Avatar
Default Re: Oil problem....... (1.6 DOHC ED9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6 DOHC ED9 &raquo;</TD></TR><TR><TD CLASS="quote">I dont see any white smoke, the odd thing is that, my car runs way smooth when the heater is on and its set to 1, but if I turn of the heater the car runs like ****, what could cause this? </TD></TR></TABLE>
It sounds like your car is overheating..
See if the radiator is leaking..
Old Mar 15, 2005 | 11:28 PM
Same here...... And no the cars not overheating cuz the gauge says its ok... I only notice white smoke when it REALLY cold so I think its just the cold.....Still not sure...
Old Mar 15, 2005 | 11:42 PM
FOMULA91's Avatar
I don’t have the oil problem but I always go low on my antifreeze. Don’t know why???
Old Mar 16, 2005 | 03:44 AM
CRXCrazy123's Avatar
Default Re: Oil problem....... (FOMULA91)
you could be leaking oil right into the motor in which case you might not wanna drive it any more or at lease till you flush the hole motor b/c you could realy do some damage if you keep driving it and its putting oil right into the motor that would also be the reason for the low ani freez if your lucky its just a busted seal
Old Mar 16, 2005 | 05:26 AM
mrtoastyjr's Avatar
most likley its a blown head gasket. unless its leaking at a very very high rate your not going to see it most likley. i was loosing it about 3 quarts every 3 weeks and i only noticed it if i was looking in my mirror when i pulled out from a stop
Andrew99911
Honda Civic (2001 - 2005)
Jul 5, 2017 11:46 AM
mrboobz
Apr 25, 2006 09:02 AM
bosco500
13
Oct 3, 2005 06:12 AM
maivietla
Mar 27, 2005 01:40 PM
B00STED Si
Feb 3, 2005 10:52 AM
