Can you use a vtec cam in a non vtec engine?
Old Jan 23, 2002 | 07:38 PM
Floyd91's Avatar
New User
Default Can you use a vtec cam in a non vtec engine?
Just as the topic says. I have someone that wants to buy my gude cam from my d16. They were wondering if it would work in a non vtec motor. Would it hurt anything?
Old Jan 24, 2002 | 05:39 AM
dirtySOHC's's Avatar
Default Re: Can you use a vtec cam in a non vtec engine? (Floyd91)
i dont see why you would want to......seems pointless......
Old Jan 24, 2002 | 07:50 AM
Big James's Avatar
New User
Default Re: Can you use a vtec cam in a non vtec engine? (EJ1)
Um. No.
Old Jan 24, 2002 | 08:18 AM
93LSivic's Avatar
Were you one of those kids that always tried putting the square peg into the round hole?
Old Jan 24, 2002 | 11:14 AM
Floyd91's Avatar
New User
Default Re: Can you use a vtec cam in a non vtec engine? (93LSivic)
I don't want to. I'm selling it and the kid wanted to know if it would work in his non vtec motor.
Old Jan 24, 2002 | 02:30 PM
BARF1's Avatar
lol .....
should not work ...
since vtec cam have three lobes .. and non-vtec cam should have two lobes .. (depend yours is SOHC or DOHC) ....
Old Jan 24, 2002 | 02:33 PM
DragII's Avatar
25 Year Member
Default Re: Can you use a vtec cam in a non vtec engine? (BAR-F1)
won't work.
Old Jan 24, 2002 | 04:16 PM
3.3.3's Avatar
Default Re: Can you use a vtec cam in a non vtec engine? (DragII)
you need the head, VTEC solenoid and a VTEC ECU.
also a little wiring knowledge.
Old Jan 24, 2002 | 04:19 PM
kefka's Avatar
heeh**
Old Jan 24, 2002 | 04:26 PM
SuperTwinz's Avatar
joking right?
Old Jan 24, 2002 | 04:28 PM
SpeedracerS4's Avatar
hehehe....
Old Jan 24, 2002 | 05:35 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Can you use a vtec cam in a non vtec engine? (SpeedracerS4)
Well, I don't think it would hurt anything. The middle lobe would just flap around in there doing nothing. It would still work, but since the cam is made for a Vtec motor, the remaining lobes wouldn't have enough lift probably......
So, yeah, it'd probably work, but make the car slower. Heh.
Old Apr 14, 2020 | 12:08 PM
Mikebmix's Avatar
Originally Posted by SpeedracerS4
hehehe....
Pretty sure non of you are real Honda guys cause if you where you would know how vtech works and that yes it has a larger more aggressive grind to them the reason being is that the rockers work on a hydraulic solenoid and at higher rpm it kicks in giving you more power if you take the Cam and the rockers off of the vtech head you can get these retainers that lock all three lobes together both on intake and exhaust you would get a little more lope at idle and more power in the upper hand I hope I didn't school you kindergartens to much seeing how most of the post where laughing not understanding just how much power you can gain with it look that **** up on YouTube the Texas Honda guys channel has a video where he swaps a vtech can into a non VTech motor so go ahead and laugh dumbasses while me and mine go faster then you
Old Apr 14, 2020 | 01:46 PM
spAdam's Avatar
Loved
Community Favorite
A+++ first post on a thread old enough to work in a strip club. Thanks for the attempt at mansplaining how
Originally Posted by Mikebmix
vtech
works!
Old Apr 14, 2020 | 04:28 PM
NukeNinja's Avatar
... I hope I didn't school you kindergartens to much...
If they were in kindergarten in 2002, that means they are 24 now, maybe with their own kids in kindergarten. Also, you would fail kindergarten with that spelling and grammar.
Old Apr 14, 2020 | 09:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
(I am) Pretty sure non (none) of you are real Honda guys cause (because) if you where (were), you would know how vtech (VTEC) works and that yes it has a larger more aggressive grind (only on the VTEC lobe... the primary and secondary lobes are smaller than a non-VTEC cam) to them. (T)the reason being is that the rockers work on a hydraulic solenoid (a solenoid is an electrical device - and in a VTEC engine, it opens a pathway inside the cylinder head to use oil volume under pressure to mechanically lock rocker arms together to switch to the more aggressive cam lobe profile) and at higher rpm it kicks in giving you more power. (I)if you take the Cam and the rockers off of the vtech (VTEC) head you can get these retainers that lock all three lobes together both on intake and exhaust (nope) you would get a little more lope at idle and more power in the upper hand (hand ???)(this doesn't work in any case that I am aware of, and even if you could move over the cam and rocker arms, you would have to make it a "vtec killer", which I believe is what you are describing when you say "retainers" even though what would actually happen is you would swap or replace the rocker arm dowels to keep all three lobes mechanically locked at all times. This would idle poorly and lose power in the low and mid-range... and make the same power as a VTEC engine of the same type at peak... not better.) I hope I didn't school you kindergartens (kindergarteners) to (too) much (I am confident not a SINGLE individual here is feeling "schooled" by you at this juncture.). (S)seeing how most of the post where laughing (WHAT !?!?) not understanding just how much power you can gain with it (I have already covered this... you can gain no more than the VTEC headed engine that is similar to the non-VTEC one) look that **** up on YouTube(.) (T)the Texas Honda guys channel has a video where he swaps a vtech (VTEC) can (cam) into a non VTech (VTEC) motor(,) so go ahead and laugh dumbasses while me and mine go faster then you (I am confident that "you and yours" are not faster than many of the veterans here are because they truly understand these engines and how to make power instead of buying into the "hype" that you are pedaling.)
Bumping an eighteen year old dead thread is a Forum Faux-pas... making fun of members here or berating them on your first post is just plain rude. Since you have nothing productive to offer, please go away.
heflin94eg
14
Dec 6, 2012 03:53 PM
psychobear85
17
Mar 11, 2009 12:17 AM
MyLilHatch
Apr 10, 2006 11:58 AM
allmotorEG-SI
Jun 4, 2002 11:47 AM
