h22 crank in h23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic »</TD></TR><TR><TD CLASS="quote">is it possible to put a h22 crank in a h23 motor. And if u use the h22 crank in the h23 block do i haveta use the h22 pistons as well?</TD></TR></TABLE>
it would be easier to slap the h23 head on a h22 block. but why would you want to destroke the h23?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic »</TD></TR><TR><TD CLASS="quote">And if u use the h22 crank in the h23 block do i haveta use the h22 pistons as well?</TD></TR></TABLE>
You can use either pistons but which ever crank you use, you will
have to use the same rods as the crank.
