what the hey..
Old Mar 15, 2005 | 06:59 PM
ms e kay's Avatar
Default what the hey..
1)im not sure if its my cat or not.. but theres this rattling noise and great vibration i feel/hear as i get off of first gear.. and it happens off of 2nd gear sometimes as well.. i can feel it rattle out thru my exhaust.. hah`.. i dunno.. any ideas?
2) i re-installed my stupid sidemarkers.. they turn on with my headlights n everything.. but my hazards wont blink.. and my left turn signal wont blink [nor tha head/taillights].. but my right turn signal does.. and this all happens when my headlights are on.. but when my headlights are off.. everything works fine.. all the wiring is correct and no fuses are blown.. any ideas?
Old Mar 15, 2005 | 07:07 PM
95cxhatch's Avatar
Default Re: what the hey.. (ms e kay)
as for your rattle, probly your heat shield
as for your lights...i suggest re-wire them, that sounds weird
Old Mar 15, 2005 | 07:12 PM
Missing_In_Action's Avatar
As for your exhaust problem, check the 2 spring bolts that connect the cat to the end of your header, most likely you are missing 1 of those bolts or it is becoming loose, also check the area around your shift linkage to see if there is good clearance between that and your cat.
bonstokLS
Jan 4, 2009 06:48 PM
cameron4776
Dec 3, 2007 05:19 AM
95GS-R801
Aug 18, 2007 07:13 AM
starbury
Feb 15, 2005 05:09 PM
Cyber ITR
Jan 8, 2004 10:01 AM
