2.2 VTEC type S active torque transfer system
Old Mar 15, 2005 | 05:52 PM
xriss55's Avatar
Default 2.2 VTEC type S active torque transfer system
what could be wrong??........engine management light for ATTS has come on??
any ideas guys whats the problem ?? cost to fix etc...cheers chris
Old Mar 15, 2005 | 06:21 PM
steveobb4's Avatar
Default Re: 2.2 VTEC type S active torque transfer system (xriss55)
Go to an auto parts store and see if you can rent an obd2 scanner. The diagnostic plug in should be under your dash on the drivers side. Get the code .
Old Mar 15, 2005 | 07:39 PM
PrettyLude's Avatar
Default Re: 2.2 VTEC type S active torque transfer system (steveobb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveobb4 &raquo;</TD></TR><TR><TD CLASS="quote">Go to an auto parts store and see if you can rent an obd2 scanner. The diagnostic plug in should be under your dash on the drivers side. Get the code .</TD></TR></TABLE>
the atts light will come on if the check light is on together, the diagnostic plug is on the passenger side under your radio there is a panel that pops off, pop off the panel and there you see it
jlowellintegra
Oct 27, 2010 07:38 PM
Slow-EJ8-4Now
Jan 9, 2007 09:34 AM
Hesh
Aug 5, 2005 03:56 PM
sicx
Apr 16, 2004 09:38 PM
omega_0000
Mar 23, 2004 10:09 PM
