turbo gsr..do i need ecu upgrade?
i have a turbo gsr 95 just installed still with stock injectors and fuel pump and ecu but with fmu, fuel preasure regulator and a p28 chip from my old setup so im running really rich the question i have is can i run like 5 pounds of boost till i get more money for injectors pump and tunning and aftermarket ecu
yes, it would be smart to look into hondata or learn to use uberdata
you can still use your chipped p28 for either or though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUTKAST_R »</TD></TR><TR><TD CLASS="quote">correct me if im wrong please but i think chrome is the program used to write the chip i think uberdata and chrome are the same ?
No, Crome and Uberdata are two completely different ROM editors. Both are similar in many respects to each other and to Hondata, however they are indeed separate programs. The programs used to write the chip vary according to what type of chip burner you're using. I personally favor Crome over Hondata or Uberdata.
thats great and all and ill probably end up doing the uberdata but what im talking about is for the mean time can i get away with driving that car like that with out any issues like i said i have the fmu ,fuel preasure regulator,skunk2 chip already installed for the my skunk2 stage2 cams which i took out and put stock back in thats why is running really rich and of course a map check valves to allow boost let me know guys thanks
h9civic3
Engine Management and Tuning
May 24, 2015 07:55 AM
Acura_I-RS
Jan 30, 2003 06:44 PM
