need advice on how to remove rust inside pipes.
Old Mar 15, 2005 | 01:39 PM
RACEPAK's Avatar
Default need advice on how to remove rust inside pipes.
hello everybody
i just got me some straight and bended pipes for my chargepipes setup and there is some rust inside and outside the pipes.
how can i get rid of thw rust inside the pipe?
i was thinking about gelvnize them inside and out.... do i need to get gid of the rust before the galvanization?
(my dad isnt sure but he think that the shop that does this process have some kind of acid that will remove the rust.... could it be?)
best regards moshik galimidi
Old Mar 15, 2005 | 02:17 PM
Ekasey's Avatar
Default Re: need advice on how to remove rust inside pipes. (RACEPAK)
We usually glass bead to outside
you can use a flapwheel or some scotch brite with wd-40 as well
Old Mar 16, 2005 | 07:40 AM
jweller's Avatar
Default Re: need advice on how to remove rust inside pipes. (eLusive ek4)
eastwood sells a rust encapsulator paint. you just paint right over the rust and your done. no idea what kind of heat it can stand up to. you could always call them and ask.
Old Mar 16, 2005 | 08:06 AM
NJIN BUILDR's Avatar
"navel jelly" should do the job.I'm sure its available world wide.
http://www.permatex.com/produc...olver
There are several manufaturers that make the stuff.
Glenn
Old Mar 16, 2005 | 01:55 PM
Bjorn's Avatar
Default Re: need advice on how to remove rust inside pipes. (NJIN BUILDR)
try soaking it in Coke
Old Mar 16, 2005 | 02:48 PM
RACEPAK's Avatar
Default Re: need advice on how to remove rust inside pipes. (Bjorn)
ok.... i got the rust under comtrol.....
now what do you say about the galvanizing the chargepipes ?
Old Mar 16, 2005 | 03:56 PM
Crasian's Avatar
i say you save your money and just paint them
Old Mar 17, 2005 | 11:24 AM
RACEPAK's Avatar
Default Re: (FarOutCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FarOutCoupe &raquo;</TD></TR><TR><TD CLASS="quote">i say you save your money and just paint them </TD></TR></TABLE>
i want them to last....
95_Civic_4dr
Jan 14, 2009 07:06 PM
ozvena
Paint and Body
Aug 18, 2008 03:40 PM
deviant1
Jun 30, 2004 04:20 AM
hw3679
Apr 5, 2004 10:07 PM
