Stock 96 EX Cat on 93 Si Hatch?
well its a VX hatch but im putting a si motor in it. i need a cat to make the new exuast work right since the VX cat comes off the header .. Will it fit correctly?
I dont know if by Si you mean 99-00 Si B16A2 or 5th Gen Si D16Z6.
Either way your B pipe runs all the way up to the header so you're gonna have to get it cut and flanged to make room for whatever cat you wanna use.
If you're using a 96 Cat, that's a OBDII cat so it has a hole for an o2 sensor, if you're using a B16A2 (OBDII) motor then perfect because you need the second o2. But if you're using a D16Z6 (OBDI) then you're gonna need something to plug that hole in the cat.
Do you need to run a cat? It should fit but your going to have to plug the extra sensor hole or leave it in the cat.obd2 cats have a extra sensor if im correct. Also depends on the exhaust, im confused which exhaust or header are you going to run then the si motors one? If so i think all ex, si cats are the same but the new ones just have the extra sensor, anyone correct me if im wrong.
all 92-95 civic si cats are exactly 15.50 inches long. just measure the ek one and you'll know your answer. hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">all 92-95 civic si cats are exactly 15.50 inches long. just measure the ek one and you'll know your answer. hope this helps</TD></TR></TABLE>
He's using a VX car/Exhaust, since the VX has the cat integrated into the manifold the exhaust B pipe is longer, so it needs to be cut if he wants to fit a cat.
sorry i guess i wasnt clear enough...
93vx swaping in Z6 with stock Z6 exhaust manifold.
Got a new exhaust but in need of a cat, got one for free from a 96 ex(yes it has the hole, but i have plug) just need to know if will work with the rest of my exhaust because i dont want it to be longer or somthing and have my exhaust sticking waaaay out, you know!!
thanks for the quick replys though!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:s h a w n D:. »</TD></TR><TR><TD CLASS="quote">sorry i guess i wasnt clear enough...
no it wont work,, you cant use your vx b pipes and make the cat work.. you can use the 96 cat if its the same size as i stated above. along with your z6 oem exhaust manifold , and any 92-95 civic b pipe (not vx) or any 96-00 bpipe. or integra b pipe . the cat will fit on all.
so in the end you need to change your vx b pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:s h a w n D:. »</TD></TR><TR><TD CLASS="quote">Is a stock 92-95 Si cat the same size as a 96ex cat?
i wont be able to measure for a couple of days..
but i wanted to be 100%, helps me sleep at night
it should be and same goes for the itr b pipe since you can put both ek and dc2 b pipes on a 92-95 civic with oem cat (not vx) and it all matches up fine...so it should be exactly 15.5 inches
</TD></TR></TABLE>it should be and same goes for the itr b pipe since you can put both ek and dc2 b pipes on a 92-95 civic with oem cat (not vx) and it all matches up fine...so it should be exactly 15.5 inches
tronic
Mar 14, 2011 06:45 AM
