b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor?
Old Mar 15, 2005 | 09:49 AM
type-t's Avatar
Default b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor?
hi,
i bought a 90 civic hatch si with a b16 dohc v tec head and b18a1 block (i believe its from an integra ls) i get code 23 ..i have searched and i keep getting the same response that the ls block doesnt have a knock sensor
i also get backfire occasionally
the computer # is 37820-pw0-000
250-317818MA
im not sure if its a p28 or a po6 the computer also has writing with permanent marker "SIR V TEC"
i didnt do the swap so i dont know what to do..ive searched but i cant get a concrete answer ....please help
mario
Old Mar 19, 2005 | 06:03 AM
type-t's Avatar
Default Re: b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor? (type-t)
i need your help
Old Mar 19, 2005 | 06:15 AM
njandrewg's Avatar
23 Knock sensor
https://honda-tech.com/zerothread?id=978933
NJIN BUILDR's Avatar
The pwo ecu is obdo and never cam in a car with a knock sensor.I believe your reading the code wrong or the wrong code chart.
Glenn
Old Mar 19, 2005 | 06:25 AM
type-t's Avatar
Default Re: b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor? (NJIN BUILDR)
i know how to read codes..thats not the problem.
like i was told before, that ecu has a knock sensor programed into it and the block doesnt have a knock sensor. has anybody ever heard of a pwo getting tweeked by uber data or getting reprogrammed so it doesnt .
is there anyone with this swap..if so what ecu are you using?
Old Mar 19, 2005 | 06:27 AM
type-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The pwo ecu is obdo and never cam in a car with a knock sensor.I believe your reading the code wrong or the wrong code chart.
Glenn</TD></TR></TABLE>
i know how to read codes and i just checked it again and its giving me code 23
long--long--quick-quick-quick
Old Mar 26, 2005 | 01:11 PM
foggsrex's Avatar
"The pwo ecu is obdo and never cam in a car with a knock sensor.I believe your reading the code wrong or the wrong code chart."
the pw0 ecu is in a b16 1st gen and does have a knock sensor....
i have the same code but i think mine is broken, you should just get a chip that eleminates that
slob20ef
May 31, 2009 06:11 PM
type-t
Mar 19, 2005 03:46 PM
CRexcellence
Apr 29, 2003 09:05 AM
clean99teg
Sep 21, 2002 05:43 PM
