NSX REAR calipers on a EG6 with ITR 5 lug conversion NEED HELP!!!
Old Mar 15, 2005 | 08:28 AM
hovic's Avatar
Default NSX REAR calipers on a EG6 with ITR 5 lug conversion NEED HELP!!!
Hi guys..
I got a set of NSX rear calipers for my EG6 for a great deal. I´ve used the search function but all informations I could find were about the frot caliper upgrade. I´ve got a 4 piston big brake kit at the front so thats not my problem.
I´ve done a ITR 5 lug conversion and now I´ve got a few questions about the setup.
-What brake cables shell I use because of the lenght
-What rotors shell I use because of the 5 lug conversion I think NSX or Legend are the same...aren´t they ?
And what modifications will I have to do to get the correct position to the rotors. I was old a long time ago that i have to use a distance bracket (spacer) but I don´t know if this is true.
Please give me all informations about it cause I realy couldn´t find anything :-(
thanx
Old Mar 16, 2005 | 01:20 PM
hovic's Avatar
Default Re: NSX REAR calipers on a EG6 with ITR 5 lug conversion NEED HELP!!! (hovic)
please help me guys :-(
Old Mar 19, 2005 | 01:04 AM
egtwincam's Avatar
Bump
Old Mar 19, 2005 | 01:15 AM
komat's Avatar
https://honda-tech.com/zero...age=1
Old Mar 19, 2005 | 08:39 AM
hovic's Avatar
Default Re: NSX REAR calipers on a EG6 with ITR 5 lug conversion NEED HELP!!! (komat)
Its only for the front again. I´m looking for a REAR brake conversion!!!
Old Mar 20, 2005 | 02:21 PM
hovic's Avatar
bump
Old Mar 25, 2005 | 09:57 AM
DC2 to AP2's Avatar
i have this setup up my itr suspension. things you will need to get it to fit.
you can use your stock brake lines and ebrake cable
rear nsx rotors
fastbrake adapter bracket
thats it and good luck
Old Mar 30, 2005 | 09:40 AM
hovic's Avatar
Default Re: NSX REAR calipers on a EG6 with ITR 5 lug conversion NEED HELP!!! (imola-red dc2)
Thanx for your reply!!
I cannot find the needed adapter bracket at fastbrakes :-( Which one do you mean?
Old Mar 30, 2005 | 10:46 AM
DC2 to AP2's Avatar
http://www.fastbrakes.com and look for the number off the website. bryan is in the process of making some more brackets for the rear calipers. give him a call and he can fab up a set for you. GL.
Old Mar 31, 2005 | 10:45 AM
JDM H22A's Avatar
let me know how things go with the rear brakes i would like to get nsx brakes in the rear
McD6288
May 6, 2016 05:52 PM
CoryDHorne
May 23, 2014 09:16 PM
Dcsports92
Feb 27, 2008 05:20 PM
hellogsr
Jun 5, 2006 06:39 PM
hovic
Mar 15, 2005 08:27 AM
