GSR Gauge Cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">WAIT!!! You'll also need the 3 dash plugs off a 94-01 Integra underdash harness.</TD></TR></TABLE>
Technically you'll only need 2 (16 & 13 pin) unless his car is auto. The SRS you can rewire.
Two
Two
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trust01 »</TD></TR><TR><TD CLASS="quote">sup guys, i am about to purchase a GSR Gauge Cluster, I was wondering if the GSR cluster will directly fit to EG hatch and the wiring...
thanks
Negative. Takes some work and patience.
thanks
</TD></TR></TABLE>Negative. Takes some work and patience.
you have to re-pin the wires, you can get the wire relocations from here http://www.merritr.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eG_LsV »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
What the hell are you bumping, the answer is no, it doesn't fit directly in, as stated before.
