carsound/high flow cat
Old Jan 23, 2002 | 04:19 PM
TypeR 599's Avatar
Default carsound/high flow cat
how much do they cost?
Old Jan 23, 2002 | 04:35 PM
B2FiNiTY's Avatar
Default Re: carsound/high flow cat (type R 599)
Anywhere from $99-$160. Depending on application ( bolt-on or universal).
Old Jan 23, 2002 | 04:53 PM
Wet Nudl's Avatar
New User
Default Re: carsound/high flow cat (B2FiNiTY)
There are two kinds out there. One suppose to flow more air then the other. Not sure about the part number off hand. The price B2finity quoted is about right. It also comes in OBDI or OBDII application.
Old Jan 23, 2002 | 04:59 PM
98hx99b18c's Avatar
Default Re: carsound/high flow cat (TypeRP)
$59 mufflertech.com
Old Jan 23, 2002 | 05:17 PM
TypeR 599's Avatar
whats the difference in OBDI and II?
Old Jan 23, 2002 | 05:37 PM
auto-x's Avatar
New User
Default Re: carsound/high flow cat (98hx99b18c)
$59 mufflertech.com
their cat converters are weak, after 3 months the honeycomb filter inside broke.
Old Jan 23, 2002 | 05:38 PM
ArchAngel Sabastian's Avatar
New User
OBDII cars have a second o2 sensor usually located in the rear section of your cat.
if you get a obdI type car youll have to cut out the old bung and weld it on to the new cat
Old Jan 23, 2002 | 05:40 PM
TypeR 599's Avatar
Default Re: carsound/high flow cat (Sabastian)
soo OBDII is better? tia
Old Jan 23, 2002 | 05:58 PM
tecnic1's Avatar
you need obd2 for your itr...unless you're using a chipped obd1 computer....96 and newerbd2, 95 and olderbd1
Old Jan 23, 2002 | 06:13 PM
B2FiNiTY's Avatar
You will need to get an OBDII one. 94006 probably.
Old Jan 23, 2002 | 06:15 PM
StinkyTofu's Avatar
i have a carsound cat on right now, but i do plan on upgrading to an OBD 1 ecu sooner or later. Could i just leave my o2 sensor in there instead of welding it?
Old Jan 23, 2002 | 07:43 PM
98hx99b18c's Avatar
Default Re: carsound/high flow cat (gud boi)
So what you are saying is that the carsound cat is weak, mufflertech simply sells them.
Old Jan 23, 2002 | 07:45 PM
New User
OH HELL NO I hate obd II with a firery passion but thats how you have to do it if your 96 or newer.
Old Jan 23, 2002 | 07:46 PM
New User
Default Re: carsound/high flow cat (B-18C1)
yah you cna leave the sensor in thier if you lazy like that.
PowerLeg
Oct 17, 2008 09:01 PM
DFWRSXS
20
Jan 8, 2006 05:13 PM
vtec.dc2
Dec 14, 2004 09:17 AM
typeeg
May 29, 2004 10:21 PM
warwagon
Apr 27, 2004 03:53 PM
