ITR rod bearing Color?
Old Mar 14, 2005 | 07:49 PM
JDM978's Avatar
Default ITR rod bearing Color?
i was just wonder if you guys out there know what color is the rod bearing on a integra type r? i try calling the acura dealer here they kinda dont know what should go in a ITR. they keep asking what color do i want. so if anybody can help me that be so great
Old Mar 14, 2005 | 07:56 PM
3.504's Avatar
Default Re: ITR rod bearing Color? (JDM978)
the dealer is right, the color code is for different clearances. you get it by the marks on the rod and the crank.
Old Mar 14, 2005 | 08:53 PM
JDM978's Avatar
thank for the help i guess i have to wait to take my oil pan out
Old Mar 21, 2005 | 09:11 PM
JDM978's Avatar
any1 with a ITR can tell me wat color bearing thy used from honda?
Old Mar 21, 2005 | 10:24 PM
DOHCtorTHRUST's Avatar
Default Re: (JDM978)
if its just a rebuild then wait and take a look at the the stamp on the crank/rod. with my rebuild, the shop had to get thicker bearings cause i spun my bearings and the color code didnt apply. the stamp didnt apply is what i mean cause i needed .010 over what the stamp recomended. this is the reason why people use plastigauge/measure the journals.
i've always thought that the color coding sytem was a inconvience and only help if everything is up to specs per helms.
good luck.
zilverz
Sep 8, 2005 02:49 PM
USDM EG
Jul 13, 2005 07:09 PM
boredracer408
Jan 3, 2004 08:22 PM
-16V-
Dec 27, 2002 03:38 PM
Brian_92GSR
Apr 2, 2002 01:53 PM
