greddy turbo timer install..speedo wire???
Old Mar 14, 2005 | 06:10 PM
mr. vang's Avatar
Default greddy turbo timer install..speedo wire???
okay just install turbo timer..works perfectly..only thing i need to know is where to hook the timer to the speedo wire..dont have a helms have one of those gay *** hanyes and its no help...search already and no succes..please help thanks..
Old Mar 14, 2005 | 06:23 PM
mr. vang's Avatar
Default Re: greddy turbo timer install..speedo wire??? (jdm_whore)
ttt
Old Mar 14, 2005 | 10:09 PM
PrettyLude's Avatar
what kind of car are we talkin about here? that wire is supposed to go to the speed sensor wire
Old Mar 17, 2005 | 06:16 AM
mr. vang's Avatar
Default Re: (PrettyLude)
96 civic ex
Old Mar 17, 2005 | 07:05 AM
s2kdre's Avatar
Default Re: (jdm_whore)
i hooked mine up in the back of the cluster.
Old Mar 17, 2005 | 04:48 PM
mr. vang's Avatar
Default Re: (jdmhonda)
umm..what wire might that be..
Old Mar 18, 2005 | 06:48 AM
mr. vang's Avatar
ttt
Old Mar 18, 2005 | 07:39 AM
pgpunkguy's Avatar
on the back of my cluster there is a screw right behind vehicle speed gauge... this screw is also the signal for the vehicle speed.
Old Mar 18, 2005 | 03:07 PM
lkailburn's Avatar
hook it up to the blue/white wire on the ecu. i wired in a greddy timer into my 97 dx.
a question for you. which two ignition wires did u use? for some reason sometime my timer will kick itself back on after its timed down and will turn like acc on like the radio and cluster lights.
any ideas? i think its bad wiring inside the unit but i wanted to verify which wires u had it on.
thanks
Old Mar 18, 2005 | 03:38 PM
TurboTagTeam's Avatar
Default Re: (lkailburn)
there is only 2 ignition wires that need to be spliced. I forget the colors allready... white/black and black/yellow i think, but i know that the solid white wire is the acsessory. I just hooked up my greddy timer yesterday and it works perfect.
Old Mar 18, 2005 | 04:05 PM
VRD^don's Avatar
should of bought a harness
Old Mar 18, 2005 | 04:06 PM
mr. vang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">hook it up to the blue/white wire on the ecu. i wired in a greddy timer into my 97 dx.
thanks </TD></TR></TABLE>
thanks alot..i'll try that
i didnt solder anything at all...i bought me one of these which made the install a hell alot eaiser...
https://honda-tech.com/zerothread?id=1065676
Old Mar 18, 2005 | 05:02 PM
lkailburn's Avatar
can u trace the wire and tell me which two wires are being used for ignition.
mine kicks on randomly and i don't know why
that harness is way to expensive. it should be 20 at most. if you can't soder 3 wires u must be retarded. lol
Old Mar 18, 2005 | 05:12 PM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">can u trace the wire and tell me which two wires are being used for ignition.
haha
Old Mar 18, 2005 | 09:06 PM
lkailburn's Avatar
lol
well it looks like that harness puts the blue timer wire to solid yellow accessory wire and green timer wire to black/yellow stripe.. i had it like that but the timer only worked like 30% of th total time. so i changed the blue timer wire to the white/black stripe ignition wire and its been working 90% of the total time.
i heard from a few others that greddy electronics are known to be flaky
i think im gonna open it up and look inside the timer for bad connections cuz im not sure whats goin on
Old Mar 18, 2005 | 10:57 PM
PrettyLude's Avatar
lots of people have problems with that turbo timer, because its just not consistent sometimes, and everything is hooked up right
i switched to an hks one, and never looked back
Old Apr 20, 2005 | 01:48 PM
EKhothatch's Avatar
My speed jumps with this one everyonce in a while. Could it be because the purple wire isn't hooked up to the speedo wire in the cars harness?
JadeGreenEF9
Sep 20, 2006 03:03 PM
turbob16a522
Jul 3, 2005 08:49 AM
Stylinhonda
Jan 4, 2005 11:31 PM
Flamenco-T
Nov 6, 2001 06:54 AM
