cleaning throttle body
Old Mar 14, 2005 | 05:59 PM
shooitzlinh's Avatar
Default cleaning throttle body
when i drove my car it started to idle at 3k but if i tapped on the gas real quick it would go back down to around 800 and so i tried cleaning it with throttle body cleaner but that didnt solve the probelm so my question is should i take the plate off and the throttle rotor off. then take off the throttle rod and clean inside that hole that holds the rod also
Old Mar 14, 2005 | 06:33 PM
Default Re: cleaning throttle body (shooitzlinh)
can anyone help me
Old Mar 20, 2006 | 04:09 PM
eshir19's Avatar
check the tension wire of your throttle body. u might have something stuck or the tension is way too tight. u might also need a little lubrication so spary some WD-40 on the joints u see on the throttle body.
ILS_09
Aug 31, 2009 11:21 AM
Gsr.Turbo'd.Teg
May 7, 2007 03:59 PM
FATninja19
Jun 26, 2006 10:51 PM
