cleaning throttle body
when i drove my car it started to idle at 3k but if i tapped on the gas real quick it would go back down to around 800 and so i tried cleaning it with throttle body cleaner but that didnt solve the probelm so my question is should i take the plate off and the throttle rotor off. then take off the throttle rod and clean inside that hole that holds the rod also
Re: cleaning throttle body (shooitzlinh)
check the tension wire of your throttle body. u might have something stuck or the tension is way too tight. u might also need a little lubrication so spary some WD-40 on the joints u see on the throttle body.
