Question about corner light
Old Mar 14, 2005 | 04:19 PM
simplypinoyy's Avatar
Default Question about corner light
I have this problem where the driver side corner doesnt stay lit when the headlights are turned on but when I use the left turn signal it blinks, I assume it is a fuse problem but I can't find the fuse for it. If its the fuse problem where may I find the fuse for it or what else can it be ?
Old Mar 14, 2005 | 04:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: Question about corner light (simplypinoyy)
Actually, it sounds as if the low-wattage filament of the bulb has burned out. Have you tried replacing the bulb?
Old Mar 14, 2005 | 04:36 PM
Default Re: Question about corner light (Padawan)
the bulbs are brand new, I figured it was a fuse though for that specific reason. Any other suggestions ?
Old Mar 14, 2005 | 05:08 PM
where is the fuse for the parking lights ? (the corners being lit; i dont know what the correct term for them)
Old Mar 14, 2005 | 05:22 PM
Outrun's Avatar
Put the passenger side bulb in there and let us know what happens...
Old Mar 17, 2005 | 05:29 AM
Default Re: Question about corner light (Outrun)
i'll do that and also i'll try to see if i can replace the wiring for that corner from another hatchback
-Racer X-
Jun 30, 2013 04:56 PM
Bonestock98GS
17
Nov 25, 2008 06:45 PM
asubennett
Aug 27, 2004 10:13 AM
obsidianG35
Sep 12, 2003 01:50 PM
