code 41 heater wire How to remove?
Old Mar 14, 2005 | 04:05 PM
Spence's Avatar
Default code 41 heater wire How to remove?
Alright guys i have a 95 cx hatch that was converted from 1 wire to 4 wire in the last swap which was a 98 y8 motor. I just put in a Ls motor and used the same 4 wire conversion from my ecu but i keep getting this code 41. I had thrown this code like 1.5 yrs ago and i rewired all four wires and the code went away. Do you guys think its possible that i keep burning out the heater wire?? I have tried 2 o2 sensors and still throwing the code
Thanks
Spence
Old Mar 14, 2005 | 05:15 PM
Spence's Avatar
Default Re: code 41 heater wire How to remove? (Spence)
no help?
Old Mar 14, 2005 | 08:58 PM
turtle-eg's Avatar
Unplug the o2 connector and measure the voltage of the two black wires on the engine harness side, should read 12volts.... one wire should have ground and the other 12v, if not, check what you're missing.
Old Mar 14, 2005 | 09:57 PM
Spence's Avatar
bump for more help
Old Mar 15, 2005 | 06:41 AM
EE_Chris's Avatar
The O2 heater element has a spec: 15 - 40 ohms. Is yours in spec?
Old Mar 16, 2005 | 04:40 PM
Spence's Avatar
bump for some help
Old Mar 16, 2005 | 05:31 PM
EE_Chris's Avatar
Default Re: (Spence)
The ECU is messed up - try another ECU.
Your wiring is messed up - get a meter and make sure there is continuity from each pin at the O2 connector back to its mating pin at the ECU (or terminating plug). Also make sure each wire is not shorted to ground. Make sure that there is +12v on one those wires when the ignition is on.
Your O2 is messed up - get a meter and measure the heater element.
Do you have a meter?
How about a Helms?
Can you get either of them?
If not, then what are you gonna do? You're left with visually checking the wires to make sure they aren't shorting against anything. You can make sure the fuse isn't blown. You can make sure things are plugged in. You've replaced the O2 twice with no success....if shotgunning is your approach, try another ECU - its easier to replace then the harness and its got to be one of those 3.
racingant
Sep 28, 2005 04:44 PM
ABK
Apr 19, 2005 11:14 PM
Nghtmar911
Jul 6, 2003 04:13 PM
SuperTeg95
Mar 25, 2003 07:04 PM
