Bad Rings, Blown valve guides? which one is it..
Old Mar 14, 2005 | 10:01 AM
Collateral's Avatar
B A N N E D
Default Bad Rings, Blown valve guides? which one is it..
Im actually posting this out of my friends concern.
I just recently installed a JDM Itr motor in an 1992 Hatch
The motor runs very strong, except he's getting some oil smoke (bluish grey) at higher rpms. I knoticed it more when he would go "down hill" that in the higher R's, the motor starts to smoke.
My question is,
<U>What do these syptoms sound like to you?</U>
Also, I know without seeing the car or motor, its hard to tell, but is there any tests or something I can do to check exactly why the motor is smokin?
Other then that, he is a happy camper and the car pulls very strong.
Not to mention that the motor has about 75k miles on it.
At idle and regular driving, there is absolutely NO smoke
Thanks for any help you can provide
Old Mar 14, 2005 | 10:10 AM
RTW DC2R's Avatar
does it smoke at WOT? or mainly when letting off the gas or coasting...
...IIRC, smoking while coasting or off the gas, but not while on the gas, is a sign of bad valve seals. I forget the exact explanation, someone correct me if im wrong.
edit: i suck at reading.
Old Mar 14, 2005 | 10:38 AM
Collateral's Avatar
B A N N E D
Default Re: (RTW Ryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">does it smoke at WOT? or mainly when letting off the gas or coasting...
edit: i suck at reading.</TD></TR></TABLE>I knoticed it smoked when he went down a hill by his house and when went into Higher R's <U>WOT</U> and when he would shift (being behind him) a cloud of smoke would come out..
When he is normally driving, no smoke at all comes out.
Hope this helps
Also in the cabin of the car, it smells like oil when going WOT
Old Mar 14, 2005 | 01:04 PM
BlueIntegraBoy's Avatar
Default Re: Bad Rings, Blown valve guides? which one is it.. (Collateral)
Sounds almost exactly like my B18C. It smokes going down this hill near my house, only after I stopped at the bottom and take off again. Also, it smokes after WOT when I slow down. My motor is very strong. I was told it could be my rings.
Old Mar 14, 2005 | 01:08 PM
Collateral's Avatar
B A N N E D
Default Re: Bad Rings, Blown valve guides? which one is it.. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Sounds almost exactly like my B18C. It smokes going down this hill near my house, only after I stopped at the bottom and take off again. Also, it smokes after WOT when I slow down. My motor is very strong. I was told it could be my rings.</TD></TR></TABLE>
Old Mar 14, 2005 | 01:25 PM
warwagon's Avatar
mine smokes some on wot.... don't worry about it, i bet 90% of everyone on here's smokes at wot
Old Mar 14, 2005 | 03:02 PM
Default Re: (warwagon)
Oh, and when I come to a stop at a light, I see smoke blow towards the front of the car. When I take off, there's a small cloud.
Old Mar 14, 2005 | 04:17 PM
onePOINTsix's Avatar
Default Re: (BlueIntegraBoy)
eek sounds like worn rings to me. take the car to a shop and ask for a cylinder leakage test. this will tell you if you have any serious internal problems like bent valves, worn rings etc. If i remember correctally you shouldn't have more then like 5-10% leakage on any cylinder. At first it sounded like you were running really rich and washing your cylinder walls but it sounds more like worn rings now
Old Mar 14, 2005 | 08:27 PM
fqnjdmboy's Avatar
Do a leakdown test...if you dont have the tools do a compression test...this will tell you a whole lot more rather than guessing....for your sake I hope its bad valve stem seals....good luck....
Old Mar 14, 2005 | 10:39 PM
110 South's Avatar
RTW Ryan,
Correct, smoking on start-up or decel is a sign of loose guides and or bad valve seals.
-Brandon
cu_jarrett
Jul 23, 2004 05:28 PM
ICUinMYrearview
Mar 31, 2004 12:38 PM
nekkedR
Aug 5, 2003 05:26 PM
gvillehnut
Mar 27, 2003 07:39 PM
