¿Head Gasket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92silude »</TD></TR><TR><TD CLASS="quote">ok...I had blown a headgasket and had it changed ..the guy that changed it is an idiot, and put an OEM one back in it..and sure enough...blew another one...So, I'm going to change it again, and put a copper one in it...do you guys know of any place that I could get one? I found one place but they were 200 bucks...know of anywhere that might have it cheaper?
thanks
Ryan</TD></TR></TABLE>
according to the mods in ur sig, u dont need an aftermarket hg, oem will do just fine, maybe the car is overheating and the temp gauge is broken, or u ran low on coolant, or maybe the mechanic is just not very good at changing hg's
thanks
If you do end up putting a copper one on, be ultra careful. You have to deck the head and the block to be perfectly flat and then use the spray on sealent. You can screw this up real easy and then you are burning coolant or worse.
blackccoupe
Aug 27, 2008 08:52 PM
eg2oreg6watuwant
13
Oct 24, 2007 09:51 PM
for blaming the mechanic
