greddy oil filter sandwich adapter for feed line?
Old Mar 14, 2005 | 07:55 AM
99sonicbluegsr's Avatar
Default greddy oil filter sandwich adapter for feed line?
has anyone used the fitting on the adapter for running your feed line to your turbo instead t-ing off of the factory pressure sender? i haven't purchased the adapter yet i was just wondering if it would work, I don't see why not oil is at a good pressure there. if anyone has done this or has heard of anyone doing this let me know. thanks.
Old Mar 14, 2005 | 08:26 AM
GDM Z28's Avatar
Default Re: greddy oil filter sandwich adapter for feed line? (99sonicbluegsr)
it works i do it, search.
Old Mar 15, 2005 | 06:27 PM
Default Re: greddy oil filter sandwich adapter for feed line? (civicflnum1)
ok, thanks. i did search and all that came up was post about oil pressure and temp.
Old Mar 15, 2005 | 06:36 PM
TunerToys's Avatar
It works!
We have customers that have connected both ways (sandwich and tee methods), and have not had anyone report back with problems.
We suggest going with the Golden Eagle sandwich adapter over the GReddy, as some folks have reported that the GReddy adapter ports are not truly 1/8NPT threads, which may cause you problems.
Craig @ Tuner Toys
Old Mar 15, 2005 | 06:42 PM
Default Re: greddy oil filter sandwich adapter for feed line? (TunerToys)
where can i get the golden eagle one? anyone know? thanks for any help
Old Mar 15, 2005 | 06:47 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerToys &raquo;</TD></TR><TR><TD CLASS="quote">It works!
yup, the threads are 1/8" BSPT. I just tapped my greddy plate for 1/8"NPT today just to simplify things.
This type of oil feed is great too. I use an oil filter plate on many of the hondas i turbo. looks good, works perfectly and has several other oil feeds for gauges. The greddy ones do tend to leak though.
Old Mar 15, 2005 | 08:14 PM
dustin's Avatar
Default Re: greddy oil filter sandwich adapter for feed line? (Bailhatch)
I have the greddy sandwich adapter. I used a 1/8 BSPT to NPT adapter (from autozone) with it for my feed line.
Old Mar 15, 2005 | 09:28 PM
TunerToys's Avatar
We have them here - http://tunertoys.zoovy.com/category/goldeneagle/
Craig
Old Mar 15, 2005 | 10:20 PM
macrosshn's Avatar
the son and the heir
Default Re: greddy oil filter sandwich adapter for feed line? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">I have the greddy sandwich adapter. I used a 1/8 BSPT to NPT adapter (from autozone) with it for my feed line.</TD></TR></TABLE>
would you happen to have a part number for that or should i just ask someone at the counter?
twkdCD595
Aug 23, 2007 05:12 AM
CivicVX94
Feb 18, 2006 07:13 PM
zeroz
Oct 15, 2005 08:52 PM
russian_accord
Mar 27, 2005 07:52 AM
