need help with str cam gears
Old Mar 14, 2005 | 06:51 AM
machine4321's Avatar
Default need help with str cam gears
i dotn understand what the markings mean on the str cam gears 570 pro
theres no numbers just a lot o flines that dotn seem to match up to anythign lol
help please
thanks
Old Mar 14, 2005 | 08:25 AM
PrettyLude's Avatar
the lots of lines you are referring to is probably the adjustment place that tell you where the cam gear is set at, make sure they are at zero before you install them
Old Mar 14, 2005 | 08:42 AM
well there at zero now...the lines arnt like other cam gears were one tick is 2 degress or sometihgn
ill get a pic up soon
Old Mar 29, 2005 | 12:26 PM
BDL IND's Avatar
Default Re: (machine4321)
Each line is its own timing mark 1 is 1 and 2 is 2.
Take the line on the outer, example 2 over from zero, do the same thing on the inner(2 over from zero) align those two marks, you have just adjusted the gear two degrees. also check out this diagram, it makes it a littel easier to understand. Ifyou have any other qwuestions please let me know.
http://www.bdlind.com/oli.htm then click on adjusting the timing
Old Mar 29, 2005 | 02:07 PM
SOHCmaster's Avatar
Are they possably set up like the new Golden eagle cam gears ? if so they have instructions on there web site, might wann check it out to see..
Old Mar 29, 2005 | 03:44 PM
the link bdl posted worked fine .....once i saw in the pics its a very good way to do it ...no more 10 degress clumped up in a half an inch spot
o_Rage_o
Nov 10, 2016 06:32 PM
skata89
Nov 26, 2006 05:00 AM
Brewer
Feb 2, 2005 10:48 AM
Brewer
Jan 13, 2004 10:58 AM
