what wideband?
How about the AEM?
I can get one of the gauge type ones for about $315... but I don't want to leave it in my car all the time and attract more theives...
How does the AEM compare to the PLX-M300 which is the other one I'm considering?
The Zeitronix zt-2 is pretty cool cause it has it's own datalogging software if you dont want to set up your ECU for datalogging. Plus it's pretty inexpensive too..I got mine for $279 +$20 (overnight S/H). One problem with the ZT-2 is it has a "parabolic voltage to AFR curve" whatever that means. It looks like bigwig has come up with a solution that allows you to use the zt2 with UD datalogging. I guess before, the parabolic volt-AFR would cause funky AFR readings to come up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">pretty much any wideband out there that has the 0-5v output would will work i used the plx with great success.</TD></TR></TABLE>
PLX is definately good for the money!!!..
