b16a2 swap for 93 civic
shift linkage, p28ecu, throttle cable or diff bracket... you can use SI or GSR axles I believe... you may need a few mounts im not sure, I had a 93 ls block with my b16a2 head so mine was alittle more complicated, just look it up in the search
I think that you will need a p30 ecu, 94 integra axles, mounts, shift linkage, make your own throttle cable bracket, poss some wiring if your car does not have vtec. I think thats it, Ive done mine last year.
i have no clue what ecu i have, but i got the motor, transmission, ecu, and wiring harness all together. engine swap package. what ecu would that be?
dzminiz
Nov 10, 2004 01:14 PM
DragInteg
Oct 27, 2004 08:41 PM
