i installed ls/vtec in an AUTOMATIC car today.........
Old Mar 13, 2005 | 05:50 PM
philipwight's Avatar
Default i installed ls/vtec in an AUTOMATIC car today.........
works great but with the p72 ecu the car has a rev limit of 5k and doesnt shift correctly. how could i get this to work correctly, has anyone done it? with the LS computer in it the car runs good but no VTEC, i could install an VAFC but the car would still ahve a rev limit of 7k with the ls ecu. this is an obd2a car. Just looking to get some input from other people.
Old Mar 13, 2005 | 07:38 PM
Dragline's Avatar
Default Re: i installed ls/vtec in an AUTOMATIC car today......... (philipwight)
get a msd
Old Mar 13, 2005 | 08:01 PM
Kendall's Avatar
Some of the JDM engine importers can probably get an automatic P72 from an Integra SiR VTEC that would suit this application perfectly, without having to ghettofy anything.
Old Mar 13, 2005 | 08:27 PM
Dragline's Avatar
Default Re: (Kendall)
jdm auto p72 will still have a low rpm rev limit and the reason it doesn't shift right is the trans goes into limp mode and only has 2nd and 4th gear.
Old Mar 13, 2005 | 08:38 PM
Kendall's Avatar
Default Re: (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">jdm auto p72 will still have a low rpm rev limit and the reason it doesn't shift right is the trans goes into limp mode and only has 2nd and 4th gear.</TD></TR></TABLE>
And can you offer a logical explanation for why you think so?
philipwight stated that the original automatic ECU allows the car to run correctly, just without VTEC, naturally because it's a non-VTEC computer. The P72 he probably has is a manual P72, completely lacking the ability to work with the automatic tranny, thus causing the incorrect shifting and the limp-mode induced 5k rev limit.
A JDM automatic P72 should correct this situation as it has all the necessary capabilities that the stock automatic ECU has, and it has the additional provisions for VTEC including a higher rev limit.
Old Mar 13, 2005 | 08:51 PM
Dragline's Avatar
No I know what he posted I was explaining to him what happens to the trans with out the auto ecu I think you have a ego problem not everybody knows as much as you or I.
I didn't know this was your post and no the JDM P72 auto does not have a rev limit as high as a manual one does but I do agree it is higher than his stock ecu and offers vtec.
Old Mar 13, 2005 | 09:01 PM
mmuller's Avatar
Mad Scientist
chipped auto p28 maybe
fryman
Dec 31, 2009 10:29 AM
GSRBrent
Nov 18, 2007 12:54 AM
kidrolla
Jan 26, 2005 07:12 PM
shinji666
Aug 23, 2004 08:06 AM
streetlvlhatch
Apr 17, 2004 02:57 PM
