opinions... gsr rebuild... what would you do?
Old Mar 13, 2005 | 03:47 PM
esohsee's Avatar
Default opinions... gsr rebuild... what would you do?
i'm getting a cheap gsr swap that needs a rebuild... was wondering if i should get a b16 head or stick with the gsr head? i've heard good things about the b16 head... just wondering if it's worth the trouble...
planning on putting spoon rods w/ spoon pistons...itr valvetrain... which head would be better with this kind of setup... i was also thinking or getting some cams like maybe buddy clubs 3... any input would be useful thank you....
oh yea after the rebuild i woul dhave to break in the motor... should i do that with stock cams? or just leave the aftermarkets in there?
thanks
Old Mar 13, 2005 | 04:03 PM
sheepey's Avatar
let me ask you this... WHY spoon rods and pistons?
Old Mar 13, 2005 | 04:19 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (sheepeg3)
Keep your OEM rotating assembly, blueprint & balance it. Might want to pick up some CTR pistons, port the B16 head, use Crower or Ferrea valvetrain, get some wild cams, an ITR IM & Header.... ****, theres a lot you can do. Search for "Poor mans type R" and you'll find some useful information.
You can break in a motor with new cams.
Old Mar 13, 2005 | 04:25 PM
5STAR3's Avatar
Default Re: (LSVTEC 91 Civic)
does spoon even make rods?
anywho, keep your stok rods like these guys said, and if you want to upgrade on pistons go with a pr3, p30, or pct
oh yea, and this is a good site www.allmotor-question.com
esohsee's Avatar
dude... i don't know... i have the spoon rods (got them for like 260)... i'm new at this b series stuff...
i heard that CTR pistons would yield too much compression (thats what i heard)...
my main question is... b16 head or stick with the gsr... i also heard that the b16 heads are of the same castings of a type r head... is the stuff i read true? thanks?!
Old Mar 13, 2005 | 04:27 PM
5STAR3's Avatar
Default Re: (esohsee)
in short, stick with the gsr head.
Old Mar 13, 2005 | 04:31 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esohsee &raquo;</TD></TR><TR><TD CLASS="quote">i also heard that the b16 heads are of the same castings of a type r head... is the stuff i read true? thanks?!</TD></TR></TABLE>
a Type R head is the same as a B16 head, except for the following things. Type R heads are hand ported, and come with the uber l33t Type R valvetrain and LMAs. Do a search, this stuff has been discussed many times.
You can make a lot of power with a "Poor man's type R" if done correctly.
Search.
Old Mar 13, 2005 | 04:55 PM
NA425DragSter's Avatar
* B A N N E D *
spoon rods are just stock honda rods rewrap by spoon, but ill go with a stock bottom end apr rod and head bolts, ctr pistons, gs-r head, ctr cams and springs.and skunk2 manifold.
RSX2SIcivic
Dec 31, 2008 03:57 PM
spoonef
11
Jun 12, 2008 12:58 AM
snowpro127
Apr 10, 2008 02:01 PM
gsr173
Mar 10, 2008 11:03 PM
2000EK4
May 20, 2006 12:02 PM
