Compression THIS, compression THAT
Old Jan 23, 2002 | 10:45 AM
bojangs's Avatar
New User
Default Compression THIS, compression THAT
well i've finally finished it. that's right, the b-series compression ratio calculator i talked about months (it seems like years) ago. i know of quite a few excel based calculators but most require you to know figures such as deck clearance and gasket thickness and i know there's quite a few people out there that don't have these numbers and would benefit from something a bit simpler.. well here you go. 100% flash based drag and drop setup.. hope you like!
and for you people that were constantly answering the "what's my compression"ratio questions (like me), now you don't have to say a word.. just drop a link.. you're welcome! hehe..
hope everyone finds it useful!
http://www.bojangz.com/calculator
Old Jan 23, 2002 | 10:48 AM
Willard's Avatar
Default Re: Compression THIS, compression THAT (bojangs)
nice
Old Jan 23, 2002 | 10:50 AM
Black R's Avatar
25 Year Member
.....added to favorites.
Old Jan 23, 2002 | 10:53 AM
Johnny Tran's Avatar
Default Re: Compression THIS, compression THAT (Black R)
nice
you r0x!
Old Jan 23, 2002 | 10:54 AM
ThePunk's Avatar
Looks good!
Old Jan 23, 2002 | 10:58 AM
IntegraT's Avatar
*Mr. Burns Voice*excellent
Old Jan 23, 2002 | 11:10 AM
sgT's Avatar
sgT
Bravo!!
Old Jan 23, 2002 | 11:16 AM
Jackson's Avatar
that is some cool bojangs. *note to self... bojangs=genious*
Old Jan 23, 2002 | 11:21 AM
OBD-One-Kanobe's Avatar
New User
!muy excellente!
Old Jan 23, 2002 | 11:25 AM
sgT's Avatar
sgT
I think it should be noted that the JDM PR3 and USDM P30 are the same
and the JDM p30 is higher CR.
Old Jan 23, 2002 | 11:26 AM
BoM's Avatar
BoM
Default Re: Compression THIS, compression THAT (OBD-One-Kanobe)
damn. u should have a label to the pistons as to which car they are.
i don't have a reference to them. cause i don't want to memorize whats what.
Old Jan 23, 2002 | 11:27 AM
sgT's Avatar
sgT
Default Re: Compression THIS, compression THAT (BoM)
click "help"
Old Jan 23, 2002 | 11:28 AM
TRuST's Avatar
I like....
BoM's Avatar
BoM
Default Re: Compression THIS, compression THAT (sgT)
lol...i was just about to modify it. i just found that out.
This will eliminate alot of compression posts now.
Old Jan 23, 2002 | 11:33 AM
bojangs's Avatar
New User
good call.. i'll add that to the help section shortly..
Old Jan 23, 2002 | 11:35 AM
Type-ARR's Avatar
very nice work men
Old Jan 23, 2002 | 11:39 AM
SPiFF's Avatar
w0w .. that is nice. Any chance of adding the B20 block?
Old Jan 23, 2002 | 11:41 AM
Rob :190:'s Avatar
that is awesome!
Old Jan 23, 2002 | 01:34 PM
Zeus's Avatar
...very nice... it should be added to the opening pages of the H-T sections...
...any plans to add B20 blocks or 84.5mm over bores?
Old Jan 23, 2002 | 01:48 PM
sgT's Avatar
sgT
Default Re: Compression THIS, compression THAT (Zeus)
Dont have to add b20 block.
to keep it simple, jsut add the different bore sizes.
Old Jan 23, 2002 | 01:51 PM
ITRinEJ1's Avatar
ur the man
Old Jan 23, 2002 | 02:15 PM
bojangs's Avatar
New User
i was thinkin about adding an 84mm bore but the only pistons i know of (besides custom) that come in that size are b20's.. people would be dropping in itr or b16 pistons and giving an 84mm bore..
Old Jan 23, 2002 | 02:18 PM
sgT's Avatar
sgT
yeah, would probably be too much of a hassle to do
just because of the possible errors that could occur
Old Jan 23, 2002 | 02:25 PM
bojangs's Avatar
New User
it would be real easy to add but i just think it'd be too controversial!
Old Jan 23, 2002 | 02:42 PM
Mr. Softee's Avatar
how much thinner is each "head gasket layer" 10 thou?
