Bearing Questions
Old Mar 13, 2005 | 12:50 PM
THEUSED's Avatar
Default Bearing Questions
Alright I used the codes off my block, crank, and my rods and came up with
Mains=2 Brown, 1 Green, 2 Black
Rods= 2 Green, 2 Brown
This is the first time this Block has been apart so all of them should basically be the above right? (Yes I AM going to plastigauge) So in theory I wouldn't even have to check clearences right? But you check them just to be super sure right?
Now Hypotheticly if I were to order ACLs Id be way out of spec, right? So the people that do order them must have all of there Bearings come out as Green or most of them atleast?
Wheres a good place to get Honda OE bearings?
Old Mar 13, 2005 | 02:31 PM
Kendall's Avatar
Default Re: Bearing Questions (THEUSED)
The bearings you pulled out should be close but as you said, be sure to plastigauge the hell out of them to be sure of the specs. ACL's would be out of spec, however they are made of a differnt material that is much more forgiving when used in out of spec motors.
Regarding OEM bearings, contact len.
Old Mar 14, 2005 | 08:16 AM
THEUSED's Avatar
Thanks Kendall
90ZCREX
Sep 3, 2011 11:47 PM
eg:R
Sep 21, 2006 05:33 PM
crxhf19
May 21, 2005 04:56 PM
THEUSED
Mar 21, 2005 11:06 AM
