Help! engine/cluster problems
Old Mar 12, 2005 | 07:38 PM
PuiPui's Avatar
Default Help! engine/cluster problems
my tach and my speedo are going all over the place, sometimes when i gas it the motor bogs, however the car idles fine. the motor doesn't rev just up the cluster, unless the rpm isn't at the right spot the motor is running fine. is this a dizzy problem??
b16a2 w/chipped p28 in a eh hatch
Old Mar 12, 2005 | 11:17 PM
hatchi's Avatar
Default Re: Help! engine/cluster problems (PuiPui)
have you tried swapping ecu's?? ignitor about to take a crap?
Old Mar 12, 2005 | 11:19 PM
bananaek's Avatar
check your engine bay harness. it may of came loose? its located on the t-stat housing its 2 ground wires w/ a 10mm bolt. it would cause all your problems
Old Mar 12, 2005 | 11:22 PM
bananaek's Avatar
btw thats 1 hour worth of diag time so..... $70 please j/k
Old Mar 13, 2005 | 12:34 AM
Ls_V_TurboSi's Avatar
Default Re: (DELUSIONEK4)
Doubt this is your problem but my car did that when the alternator was dying
Old Mar 13, 2005 | 12:50 PM
PuiPui's Avatar
Default Re: (Ls_V_TurboSi)
checked grounds they are fine, gonna bring it into the shop but u guys dont think its the dizzy?
demonicivis1320
13
Sep 26, 2011 08:26 PM
Random.Hero
Sep 7, 2007 02:02 PM
edgeridercr15
Dec 11, 2003 08:06 PM
PurpleGsR00
Oct 22, 2002 11:48 AM
