Car making whinning noises 91 civic si mini me swap
The best way to describe the noise is, it sounds like a supercharger the noise seems to be near the fuel rail. We just finished the swap and one of the problems was the injectors were missing the rubber gasket that goes on the top of the injectors to the fuel rail. I replaced those and noticed that one of the screens is missing on one of the injectors( will replace that asap just gotta get one ) Has this happened to anyone I need help as this is my daily driver. thanks in advance.
Denny
Denny
Ive had this problem when I had my a6/y8 setup, the y8 timing belt was really tight. The belt eventually stretched out but I always had a whining noise coming from the head. any thoughts? did you have a hard time putting the timing belt on? which did you use? was it new?
Well I got the motor from a friend(free
) so I will have to ask him he said he had no problems with it what so ever so I will have to check. Thanks everyone for the tips I will keep you guys posted, I hope to find the noise today.
doo its the timing belt my car does it. with the mini me swap the timing belt is gunna be really tight. It will start to go away after a while.
Which timing belt is being used? It should be the d16z6 don't be using the VX (vtec-e) cause it is one less groove on the belt.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Atk »</TD></TR><TR><TD CLASS="quote">Well we found out it's the idle control valve so my question is, will any d series valve work?</TD></TR></TABLE>
depends, what intake manifold?
ekx4
Aug 28, 2006 12:18 AM
Chilly61383
Oct 18, 2005 08:44 AM
I hate it
