Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc......
Old Mar 12, 2005 | 12:06 PM
The DX Rex's Avatar
Default Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc......
bascially what kind of wheel hp will this set up yield. i am planning on having it dyno tuned at south florida performance in miami.
b16 block
ctr pistons
b16 rods
arp head bolts
b16 head
ctr intake cam
skunk2 intake manifold
skunk2 throttle body
j's racing intake
4-1 headers w/ 2.5 in. collector
2.5 catback with no cat
b16 tranny
fidanza flywheel
exedy stage 1 clutch
chipped p28
walbro fuel pump
VAFC
thanks
all this is goin in my VX hatch
Old Mar 12, 2005 | 02:32 PM
SDT Project EF's Avatar
Default Re: Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc...... (nyhustla2k)
150whp to 160whp
Old Mar 12, 2005 | 03:28 PM
5STAR3's Avatar
Default Re: Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc...... (SDT Project EF)
absolutely no way for use to tell.
https://honda-tech.com/zerothread?id=854145
let us know when you get it tuned.
Old Mar 12, 2005 | 03:43 PM
EKCivicR's Avatar
Hmm... had I buddy with similiar or identical setup but with instead mild port polish job and Skunk 2 valve train and Stage 2 cams. He put down about 190whp on the B16A2. I was like no way... but he did. Hard to believe but it's true...
He ran a 14.5 on some MT's slicks in a 99 civic si coupe.
Old Mar 12, 2005 | 04:58 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyhustla2k &raquo;</TD></TR><TR><TD CLASS="quote">ctr intake cam
trying to decide on a cheap cam setup for my b16. did you notice good gains with just the intake cam? wondering, because i was thinking of doing the same thing. doesn't look like you changed the valvetrain either, how long have you been running the ctr cam and have you had any problems? thanks.
Old Mar 12, 2005 | 05:11 PM
2k.civic.si's Avatar
Default Re: Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc...... (DelSolDon)
get some headwork done and 190whp+ is possible
1999 Civic Type-R motor.
Pretty stock.
Cam Gears
Fuel reg, 92 octane
Intake, exhaust.
Old May 1, 2005 | 08:13 PM
turbosnatch's Avatar
you'll prolly have any easy 125 whp with this setup maybe 130 ;P
Old May 1, 2005 | 08:23 PM
xEnderx's Avatar
Default Re: (turbosnatch)
2 horsepower.
Old May 1, 2005 | 08:24 PM
hondaeg8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch &raquo;</TD></TR><TR><TD CLASS="quote">you'll prolly have any easy 125 whp with this setup maybe 130 ;P</TD></TR></TABLE>
thats a gay response
Old May 2, 2005 | 03:30 PM
PAndADc2's Avatar
Default Re: (hondaeg8)
im thinkin 190 or more
Old May 2, 2005 | 04:27 PM
eg6hatch1's Avatar
u should get at least 190,, u missing a few little parts thou
Old May 2, 2005 | 04:32 PM
Professor15's Avatar
I say 180whp give or take...but its most likely going to end up in the high 170's...
Old May 2, 2005 | 07:09 PM
8krdline's Avatar
about 175hp. I've seen simliar mods putting down that much
BG-Teg
27
May 14, 2007 02:27 PM
MassScene
10
Mar 10, 2005 04:28 PM
BLUE EH3
32
Oct 13, 2004 02:08 PM
b18c-93
Mar 25, 2003 08:03 AM
All Motor EG
May 13, 2002 10:42 PM
