Apexi Power FC TUNERS! Step inside...
Old Mar 12, 2005 | 09:59 AM
AgentJam's Avatar
Default Apexi Power FC TUNERS! Step inside...
Any of you FC users get a single check engine light flash when shifting hard at redline? I'm not talking about hitting the rev limiter...it happens at the point when you engauge the next gear...almost like it's detecting wheel spin, or engine load at the point after the shift.
Vince
Old Mar 17, 2005 | 06:33 PM
AgentJam's Avatar
Default Re: Apexi Power FC TUNERS! Step inside... (AgentJam)
hmmm
Old Mar 27, 2005 | 02:04 AM
Andre's Avatar
Might be injector warning?
Try changing the flash time so you know for sure.
Old Mar 27, 2005 | 01:05 PM
AgentJam's Avatar
Default Re: Apexi Power FC TUNERS! Step inside... (Andre)
not that...i check my peak inj value and it's not near threshold. happens when i shift lower as well when the tires break...
Thanks!
Anyone else?
Vince
Old Mar 28, 2005 | 06:42 AM
Andre's Avatar
You should do map trace while shifting, because the pressure will fall rapidly while the RPM's are still high, that will set you in the upper right area of the map.
Usally you have a lot of ignition advance there and you will see see a high knock level while beeing in this area of the map.
So check you knock levels too.
Old Mar 28, 2005 | 08:11 AM
AgentJam's Avatar
good point but right now i don't have the knock warning setting "on," I'm using a z6 block and haven't fit up a knock sensor yet so even if it was on there'd be no reading.
Could it be as simple as a traction control warning? Never heard of it on the FC's but then again nobody in the US knows much about it!
Vince
Old Mar 28, 2005 | 08:26 AM
Andre's Avatar
The PFC doesn't have anything like traction control.
Could you make a log file and post it here?
Old Mar 28, 2005 | 01:51 PM
AgentJam's Avatar
I know it doesn't have traction control but maybe a no load warning light?
I don't have the FC software or box, just a commander. Sorry!
Vince
Old Apr 11, 2005 | 08:01 AM
TheShodan's Avatar
Moderator
That flash is mainly the knock sensor, for noise. For some reason in boosted applications, that seems to come on a lot.. It works ok, though... nothing to really worry about.
Old Apr 11, 2005 | 08:23 AM
Andre's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">That flash is mainly the knock sensor, for noise. For some reason in boosted applications, that seems to come on a lot.. It works ok, though... nothing to really worry about.</TD></TR></TABLE>
He said he has disabled the knock warning.
Old Apr 11, 2005 | 11:42 AM
AgentJam's Avatar
Default Re: (Andre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, it's def diabled. Maybe a spike in oil pressure or something? Hard to tell!
Vince
Old Apr 11, 2005 | 02:22 PM
TheShodan's Avatar
Moderator
The knock warning still doesn't disable that part of the sensor.... Mine does it now, and I fully tuned it with no real issues. Apex'i is starting to give more technical advise on it now.
Old Apr 11, 2005 | 02:31 PM
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">The knock warning still doesn't disable that part of the sensor.... Mine does it now, and I fully tuned it with no real issues. Apex'i is starting to give more technical advise on it now.</TD></TR></TABLE>
Why should he get a CEL if knock warning is disabled?
The PFC continues to read the knock sensor values, but you won't get a CEL any longer.
Old Apr 11, 2005 | 03:32 PM
AgentJam's Avatar
Default Re: (Andre)
Ahh...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">good point but right now i don't have the knock warning setting "on," I'm using a z6 block and haven't fit up a knock sensor yet so even if it was on there'd be no reading.
How do you explain that then hehe
Vince
Old Apr 11, 2005 | 03:52 PM
.1type.'s Avatar
i have the same problem???
Old Apr 11, 2005 | 04:05 PM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Apex'i is starting to give more technical advise on it now.</TD></TR></TABLE>
Can you elaborate more on this? Who exactly is giving more technical advise.
Vince
Old Apr 17, 2005 | 03:13 PM
TheShodan's Avatar
Moderator
Apexi POWER EXCEL Dealers should have some additional information
DonReyn
Jun 2, 2018 09:51 PM
DanB93
Engine Management and Tuning
Sep 16, 2014 09:33 PM
1993eghatch
Jun 24, 2010 03:25 PM
followthadollar
11
May 3, 2010 04:21 PM
