gsr block
Old Mar 12, 2005 | 07:48 AM
methodz55's Avatar
Default gsr block
i have a gsr block. i want to rebuild it. they told me use my gsr crank and get eagle ls rods and cp pistons with 11.5 compression. ima replace all bearings and seals and all that. so should i use those ls rods ????? what kinda set up is more reliable??
Old Mar 12, 2005 | 07:52 AM
boostin4door's Avatar
Default Re: gsr block (methodz55)
why dont u just use gsr rods?... am i missing something?
Old Mar 12, 2005 | 07:56 AM
methodz55's Avatar
thats what i said he told me its better w/ ls rods
Old Mar 12, 2005 | 07:57 AM
uhm... it dosent matter the only diff. is that the ls rods have a slightly longer stroke but if your going with forged rods id just use the gsr's and get those CR: pistons either way itll be the same CR: i just dosent make sense to use the ls ones... but then again maybe they know something i dont
Old Mar 12, 2005 | 08:01 AM
methodz55's Avatar
Default Re: gsr block (widebodyjaeg16b)
how about the crank ??? do micro-polish it or balance or knife-edge??
Old Mar 12, 2005 | 08:04 AM
you dont have to but if your looking for some better #'s and have the $ i would.
Old Mar 12, 2005 | 08:10 AM
methodz55's Avatar
thanks
Old Mar 12, 2005 | 08:12 AM
np
Old Mar 12, 2005 | 08:15 AM
methodz55's Avatar
hey what about my head??? what type of cams?? ima get port flow valve train
Old Mar 12, 2005 | 08:32 AM
NJIN BUILDR's Avatar
LS rods WILL NOT WORK with gsr crank.The rods are to short and to wide on the crank end to fit.They are not as strong as the gsr rods.There are some good books on hot rodding honda/acuras.Keep doing your research.
Glenn
Modified by NJIN BUILDR at 12:46 PM 3/12/2005
Old Mar 12, 2005 | 08:38 AM
JCushing's Avatar
Default Re: gsr block (NJIN BUILDR)
LS rods are SHORTER damn guys.... they wouldnt be long enough to use with a gsr crank and you would actually have a worse r/s ratio without even gaining displacement from the LS stroke....
IMHO a LS crank and rods in a gsr motor would be a real good street build with some JDM R pistons on there
Old Mar 12, 2005 | 08:46 AM
Default Re: gsr block (JCushing)
Typing faster than thinking again.5.394" ls,5.430" gsr.
Glenn
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
grand champ
Feb 20, 2008 10:10 AM
TurboEH2
Apr 2, 2005 11:15 AM
advanracing62
Oct 11, 2003 09:57 PM
Quicky
Nov 25, 2002 05:12 PM
