MSD problems......
Old Mar 11, 2005 | 08:51 PM
streetrage's Avatar
Default MSD problems......
I recently put a 6A MSD with blaster2 coil and pro cap on my girl's 96 civic with a B18b engine. yesterday it didnt want to turn on anymore. I checked everything, and the problem was that the cap had built up carbon deposits or whatever you call them. The msd has only been there for about 3 weeks, and the cap looks like if it's been on a car for 100,000 miles! After I cleaned the brass points the car turned on and ran fine. Could the MSD kit be the culprit??
thanks in advance..
Alex
Old Mar 11, 2005 | 11:03 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: MSD problems...... (streetrage)
OEM honda ignitions are good to around 300HP... A lot of people find the MSD boxes to be a pain in the ***.
Old Mar 17, 2005 | 11:17 AM
streetrage's Avatar
anyone else got some ideas? Come on, this is honda tech! Were are all the gurus at?
Old Mar 17, 2005 | 02:41 PM
Circuit Star-29's Avatar
Doens't sound like anything an MSD ignition would do.
Old Mar 17, 2005 | 03:37 PM
skunked's Avatar
Default Re: MSD problems...... (C-speed Racing)
do you have spark? Do you have 12volts to the coil? Do you have good grounds?
Old Mar 17, 2005 | 03:47 PM
streetrage's Avatar
ya I checked all that... Everything seemed fine. Someone told me that if moisture gets inside the cap, buildup occurs. Is this true?
Old Mar 17, 2005 | 03:52 PM
skunked's Avatar
Default Re: (streetrage)
So you do have spark? Then it's not the MSD.
Maybe your ICM took a $hit.
Old Mar 17, 2005 | 10:54 PM
Default Re: (skunked)
^ thats what I was thinking.
Old Mar 17, 2005 | 11:51 PM
85's Avatar
85
Default Re: (C-speed Racing)
My brother had a similar problem, 99' LS low miles. he bought one of those clear caps, you know the ones were you can see the spark coming from the rotor? well after changing it out a short wail later the car ran like crap and the cap and rotor were corroded BAD. the car was under warranty and for some reason the dealer agreed to change the cap, rotor and wires to the oem ones. problem solved. so i don't know what it is for sure. I installed a digital 6 on a 2nd gen B16 with a blaster2 coil. No problems what so ever! used the msd distributor cap after 20,000+ REAL HARD miles it still ran like new.
Old Mar 19, 2005 | 08:13 PM
streetrage's Avatar
Oh, it must be the cap then cuz the car has the MSD clear red pro cap. Maybe they come defective or something... The problem started right after I put the MSD and Cap, so I guess it's most likely not the module.
Thanks to all of you for your responses!
Old Mar 20, 2005 | 12:33 AM
85's Avatar
85
that has to be the prob, the clear cap was the only one that has ever given me probs...
Old Mar 20, 2005 | 07:40 PM
streetrage's Avatar
ya, im gonna warranty that bitch back to msd and get a regular black pro cap! The black one never gave me any problems!
sanman000719
Jan 8, 2009 11:17 AM
justint
Feb 24, 2007 08:46 PM
gutted-dx
Aug 21, 2004 08:15 AM
ludegirl1004
Apr 28, 2002 08:31 PM
