Can anyone help me out with this MSD "where is this wire"?
Old Mar 11, 2005 | 07:55 PM
Hondasi88's Avatar
Default Can anyone help me out with this MSD "where is this wire"?
I just freakin blew up my distributor..... anyway i have a question and if this is in the wrong section then i am sorry. I am using a MSD 6a with blaster 2 coil.....i see the black/ yellow wire which could be found outside the distributor but where is this blue/white wire at?
please post a picture!
i know that the wires are INSIDE of the distributor i just can see or find the blue and white one.
Its a 92 integra thanks for any help!!!!!
Old Mar 12, 2005 | 04:28 AM
kndaqikEG's Avatar
Default Re: Can anyone help me out with this MSD "where is this wire"? (Hondasi88)
If I am correct in my thoughts, you are hooking up the + and - from the factory coil, correct? If so then the blue and white wire is internal to the distributor only. It goes directly from the internal coil to the ignition module. You need to open up the distributor and put extensions on the + and - from the factory coil and run them back out through the grommet, or you can go ghetto like me and drill a hole in your brand new cap and put some silicone around it . I hope this helps. Good luck.
MattMcCrossfit
Jun 8, 2016 09:26 AM
eg6imola
May 24, 2008 10:11 PM
joshb_
May 30, 2007 06:36 PM
posaccord01
Mar 24, 2007 08:40 AM
94gsr
Jun 1, 2004 12:55 PM
