power window/doorlock conversion problem
Old Mar 11, 2005 | 05:00 PM
SprayinCX's Avatar
Default power window/doorlock conversion problem
i have a 96 dx hatchback and i did the pw/pl/pm conversion. i got everything out of a 96 ex coupe. i got everything in the doors and have them bolted up and everything works fine but one problem.
the power mirror on the driver side moves up and down fine but it will not move right. when you try and move it left the door lock clicks. it doesn't lock or anything,but it still makes a noise.
using the same switch and everything hooked up the way it is the passenger side mirror is perfect.
so my question is what do i need to check? cause i have checked everything and the wires are plugged into the right places.
Old Mar 14, 2005 | 06:40 PM
SprayinCX's Avatar
Default Re: power window/doorlock conversion problem (SprayinCX)
anyone thought of anything yet
Old Mar 15, 2005 | 05:31 PM
SprayinCX's Avatar
well i tried unplugging the mirror and it still does it. then i tried unplug the door lock but the mirror still doesn't move left or right.
Old Mar 15, 2005 | 06:36 PM
Synthead's Avatar
Check your wirings. Sounds like you either got something jumbled up or the person who last owned it did.
Try using this link to help you sort your problem out. I love the online honda.co.uk manual.
http://www.honda.co.uk/owner/C....html
Old Mar 16, 2005 | 02:48 AM
SprayinCX's Avatar
Default Re: (Synthead)
well it is all oe wiring. all the door plugs are are right. i have checked all that several times. the floor harness and the door harness are out of a 98 ex. so everything should be okay as far as the wiring goes.
Propulsion
17
Mar 5, 2016 03:42 PM
ERICBREEZY97K
Jun 11, 2015 11:54 PM
alexsrx7
Aug 25, 2010 09:52 AM
wesley_925
Jul 8, 2008 05:46 AM
EM2RCR
Honda Civic (2001 - 2005)
Mar 30, 2007 11:53 PM
