what rods?
Old Mar 11, 2005 | 10:41 AM
dizzyroc88's Avatar
Default what rods?
im going to be using je pistons 10.1 .20 over pistons in an h23 block...what rods could i use . would i still be able to use the stock crank?. thanks in advance
Old Mar 12, 2005 | 08:30 AM
PrettyLude's Avatar
eagles, crower, pauter, yes you can use the stock crank, just need to get the proper bearings and your set
Old Mar 12, 2005 | 08:49 AM
NJIN BUILDR's Avatar
Default Re: what rods? (dizzyroc88)
You will also need sleeves to run the JE's.
Glenn
Old Mar 12, 2005 | 09:00 AM
dizzyroc88's Avatar
Default Re: what rods? (NJIN BUILDR)
even if its not that much that they're taking off the block
Old Mar 12, 2005 | 07:14 PM
earl's Avatar
I don't think Eagle sells a rod for the H23, only the H22
Pauter H23's in stock but they are expensive.
Old Mar 13, 2005 | 05:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 &raquo;</TD></TR><TR><TD CLASS="quote">even if its not that much that they're taking off the block</TD></TR></TABLE>
The material that is used for the oem cylinder walls is not compatible with forged pistons.
Glenn
Old Mar 13, 2005 | 05:42 AM
dizzyroc88's Avatar
i forgot about that....
the rods i found were some crower billet rods
kaymoto
Sep 7, 2010 05:43 PM
GoldLudeRay
Jul 25, 2009 07:55 AM
Damir8383
Aug 13, 2004 01:42 PM
rrei
Jan 23, 2003 08:04 AM
